East West PLAY and Mavericks
Yes, I know, it's not supported, I'm building an experimental partition, but strangely, when I try and launch Play from the finder, I get a prompt asking me 'where is Applescript Runner'. So I'm mostly curious if anyone else has Mavericks up and has run Play, if they get the same thing.
Re: East West PLAY and Mavericks
I am running Play in Pro Tools right at this very moment - working good, but launching standalone I get the same prompt as you do. What the heck is Applescript Runner? I don't use standalone app at all, just a side annoyance for me though.
PT 11.2 Mac |
From apple support forums:
Hello, I will answer to karlitofingers. The instruction that mistersquid gave to EastWest problem, is not working. This is a common problem. I will post my how-to, copied from Motunation forum. ======== Tested with MacOS 10.9, Play app. ver. 4.0.23 (and 4.0.18) PLAY app works perfectly, it is a bit tricky to open it, see the instruction below: First of all, trying to open Play app in East West folder, which is in Applications folder of the computer gives a weird error: Where is AppleScript Runner? That led me to an idea that the actual Play.app is somewhere else and in Applications folder resides a script (EWQL Symphonic Orchestra.app in my case). The actual play app resides here: /Library/Application Support/East West/Play.app NB! This is Library folder on the top level of HD, and NOT in your user folder. You can make an alias of Play app and place it wherever you like to avoid navigating every time you want to open a standalone of PLAY. PS. The script that is inside Play app script in Applications folder, contains the following line: /Applications/East\ West/EWQL\ Symphonic\ Orchestra.app/Contents/MacOS/symphonicorchestra.script ; exit; Running this line in Terminal.app opens Play.app as standalone also.
PT 11.2 Mac |
Excellent, thanks, I too assumed maybe it wasn't actuality the app but a script. Just seems weird that it uses Applescript apparently.
But thanks for finding it!. |
East West Play 3 (64bit) in Beta | lincol1 | Virtual Instruments | 0 | 03-14-2011 10:25 PM |
East West Play and Pro Tools 8... Mixed information by Digidesign. | Dizzi45Z | Pro Tools TDM Systems (Mac) | 26 | 05-10-2010 08:26 PM |
East West PLAY on PT8? | lwilliam | Virtual Instruments | 3 | 07-10-2009 12:18 PM |
East West 'Play' Engine | TimNielsen | Virtual Instruments | 21 | 12-15-2008 10:43 AM |
East West Play Engine and VST Wrapper?? | Dog BBQ | Virtual Instruments | 1 | 08-13-2007 05:51 PM |
