quick help dropping samples into kontakt
I'm dropping samples into Kontakt and i simply want them to span across the keyboard chromatically in order sample 1 to 32. but its places each sample on 3 keys?? weird, so i get 96 zones etc. can't find any prefs for just placing one sample on each consecutive note. all other samplers i've used have done this by default. Chris
Re: quick help dropping samples into kontakt
In the Mapping Editor's Edit Menu, was "Chromatic" selected? Was AutoMap on or off?
I've tried every setting i can find and it just won't put one sample on one note!!! it always wants to put each sample across 3-4 notes Must be a simple way to drag and drop and have them in logical order 1-40 across the keyboard?? Chris
when you drag the samples in keep your cursor low down on the mapping window. Roughly, say, 4mm above the piano notes.
Yeh, thanks i discovered that ok, now my problem is it won't place the samples in the correct or logical order? i'm having to manually do one sample at a time to get them in the right order!! Chris
Kontakt samples library | Jakay | macOS | 9 | 10-24-2012 01:55 PM |
Free EXS24 & Kontakt samples for use in Structure | K.B. | General Discussion | 2 | 11-05-2011 01:27 PM |
Quick-key for dropping editted segment down a track?? | postman56 | Tips & Tricks | 2 | 12-31-2009 06:19 PM |
Structure free and Kontakt samples!! | scar97 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-12-2009 04:23 PM |
Pro Tools & Kontakt 3 using converted Giga samples | phatjones | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2008 11:55 AM |
