Old 01-21-2007, 05:00 PM
luts luts is offline
Default Handling large sessions when mixing.. advice??
Just looking for some tips to help with mixing large sessions.
I have lots of recording coming up.. I will most likely leave the same session open to record multiple takes and multiple songs.
My question is.. Let's say I mix the first song of the session and I'm happy with it.. How can I economically then use those same settings for the other mixes (songs in the same session) and tweak them as required? I know I could just leave the same session open but any changes would be saved.. I'm thinking it would be nice to have a separate session with each song and the ability to use the same plugs and settings from my first initial mix..
I'm looking for a smart method of working with mixes that are related to each other..
Any wisdom is much apprectiated.
Old 01-21-2007, 09:24 PM
wolfskin wolfskin is offline
Default Re: Handling large sessions when mixing.. advice??
Luts, use the 'save copy in' feature for each song (remember to check the copy all files / folders options). Rename the .pts file for each individual song. Open each song individually, delete other songs from the session, then delete unused audio (permanently, to avoid having x copies of the same audio).
The bigger your 'parent' session, the more time-consuming this process becomes. There may be a quicker way that I'm not aware of, but this should get you started.
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 01-22-2007, 11:54 AM
EGS's Avatar
EGS EGS is offline
...I will most likely leave the same session open to record multiple takes and multiple songs... I'm thinking it would be nice to have a separate session with each song and the ability to use the same plugs and settings from my first initial mix.
Since you've got all songs recorded to one giant PT session, simply "save as" each song's mix with a new name. Happy with 1st song's mix? Save as "song1". Then, advance along the timelime to song2, tweak the mix, and save as "song2". This will preserve your plugs and settings. (hi wolfskin)
Click for audio/video demo
Click for resume
Splitting large sessions into smaller sessions brandondurham Tips & Tricks 2 10-06-2013 09:02 AM
Very large sessions nosfoe Pro Tools TDM Systems (Mac) 15 12-11-2009 02:21 AM
Handling large sessions when mixing.. advice?? luts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-23-2007 02:12 PM
How do I cope with mixing large sessions? luts Tips & Tricks 3 01-22-2007 04:46 PM
Large Sessions ajazzie Pro Tools TDM Systems (Mac) 4 08-06-2002 05:46 AM
