7.3 Does Nothing, Nada, Zip
I'm one of those whose 7.3 installation on XP does absolutely nothing on startup. I have no plugins, other than those that come free with the software. The executable grows to about 33Mb in size, and then just sits there, occupying 0% CPU. I've given it as long as 30 minutes, just to see if it would start doing something, but to no avail. I've tried disabling Norton, disabling the NIC, reinstalling, and wiping out all remnants of my 7.1 installation, including the free plugins and Xpand, and installing the CS1 patch. The result is the same.
I'd like to be a little more proactive in figuring out what's wrong, but I don't see a log file or anything that I can check to see where it's getting hung up. Are there any command-line options I can use to try to figure out what's (not) happening? Where do I go from here? Thanks. |
Re: 7.3 Does Nothing, Nada, Zip
Good luck my friend!
http://www.geraldodarbilly.com |
Some things to try;
Trash the preferences and the databases. Update your PACE drivers from www.paceap.com List all of your plugins and their version numbers (the version numbers are very important). Another user was having problems and it turned out he was using old versions of some plugins and they were causing the problem.
"Trash the preferences and the databases" > Done! "Update your PACE drivers" > Done! "fresh install" > Done 3 times! "Plugins" > Try to start up the app without ANY plugin. Same thing > it won't start! I've contact the Brazil Support and they are sending me a 7.3 CD. (Thanks Quanta Music!!!) I really hope that my problem is a bad installer...if not...well...Lets see... Thanks again!
My post really was directed at the original poster.
If you're using Windows XP with service pack 2 (SP2), then you must enter the Pro Tools executable program as an exception to the WinXP Data Execution Prevention performance option:
Control Panel-->Performance and Maintenance-->System-->Advanced Tab-->Settings Button-->Data Execution Prevention Tab-->Radio Button for Turn on DEP for all programs and services except those I select:-->Add Button-->browse for PT executable and double click That should do it unless you have other issues. Checklist for configuration issues is here: Configuration Checklist |
Is this only with 7.3? I ask because 7.1 installed flawlessly here and is working fine.
Derrkins GuyBarTola ******************** PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!! |
Maybe it's only me, but I needed to enter PT into the DEP exception table for 7.1.
In trouble shooting my 7.3 installation, I moved the PT installation from my E: drive partition, to the C: drive partition (at the suggestion of Digi-tech-support). That had no effect on the problem I was working on, but when I did that, 7.3 wouldn't load, just like 7.1 before I tried the DEP entries. Once I removed and re-added the PT program (with it's new location) to the DEP exception table, it was working again. YMMV. |
OK, I've done the following:
1.) Remove all remnants of 7.1 installation, including: 1a.) 7.1 ProTools 1b.) All 7.1 Plug-Ins 1c.) Xpand! 1d.) 7.1 Documentation 1e.) ProTools Projects in My Documents 1f.) M-Audio Driver 1g.) PACE Driver 2.) Installed the following, in this order, and rebooted after each installation: 2a.) iLok Driver 10.50.0.125 2b.) M-Audio Driver 5.10.00.5036v2 2c.) 7.3 ProTools 2d.) 7.3cs1 Patch 3.) I have also tested the following: 3a.) Turned on DEP for all programs, with exception for Pro Tools 3b.) disabled Norton 3c.) disabled the NIC but still nothing. I checked the compatibility matrix, and it seems that my version of XP is not on the list (Media Center) - which is frustrating because ProTools 7.1 worked flawlessly on it. If anybody has gotten this to work, I'd appreciate hearing how. Beyond that, I think the solution may be to go dual-boot, with a separate partition for plain-old XPsp2. This is probably a better solution anyway, since I can keep that image dedicated to ProTools. Any suggestions on the best way to do this would be appreciated. If I have any issues with the dual-boot, though, I'll be back! Thank you all for your suggestions. |
Here's another thing I needed to do to get 7.1 to work:
Didn't see that in your list... Might help. |
NO SOUND. Nada, Zilch, Zero... | fourseasons | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-19-2007 09:19 AM |
PT 24MIX system bugs (seached found nada) | jseput | Pro Tools TDM Systems (Mac) | 3 | 12-28-2003 02:58 PM |
