Running out of DSP power? System limitations?
I am working with Protools HD2 version 8 and I am starting to get limitations in my sessions.
I have a 39 track session (39 voices allocated from 64) and I am using just Eq's and Compressors on each track (one of each per track), I add one bus with reverb and thats all I am able to do. When I want to add more Aux or Audio tracks it just wont let me, they turn up faded and unusable, even when I add one more plug-in it says that I dont have enough DSP. Is there something I can do with settings to get more space or is this actually all I can do? Also when I switch from output 1-2 to output 7-8 it only switches half of them and when I want to switch them one by one the busses get inactive. My session is in 96khz 24 bit. |
Re: Running out of DSP power? System limitations?
Would help a LOT if you gave us details on your system like: what specific Mac, what specific OSX version, ram, etc. Without that time here is wasted and we'd just be mucking about in the dark. There's plenty of knowledgeable people here but we're not mind readers. That's why there's a 'help us to help you' at the top of every page.
I have a Mac Pro 1,1 Dual-Core Intel Xeon, 2.66GHz, Duo Processor, 4 cores, L2 Cache( 4MB per processor), memory 2 GB 667 MHz DDR2 FB-SIMM, Bus speed 1.33GHz
OSX version 10.5.8 Protools version HD2 version 8.0.5 |
No wonder you ran out of power, you need a new computer boss..... Get a Mac Pro 4.1, SSD OS X drive and 24gb of ram, and you will feel like your in heaven And you need HD3 at least to do any real work.... My personal experience
I thought so, I dont have time and needed a quick solution but you are right, I need to update my system. I just hoped I did something wrong in the settings or more simple. Thanks a lot pal, I really appreciate your time to answer me
Cool, and a 4.1 is only about $500 USD, and a used PCI-E cars is only about $300 USD....
That will keep you stable for a few more years,
sounds like you hit the Voices limit .. am i remembering correctly .. HD2 .. stereo tracks eat up 2 voices ..
please correct me if wrong ..
Thanks a lot, its in my plans to invest in a new studio later this year so for now I will just contact my supplier to give me a quick update. For this rest of the week I just need to deal with what I have.
I am hitting a lot of limitations. I just need to update my system and I think you are right on that.
Thank you for you reply |
I moved some systems from HD3 to HD Native and was/am pretty happy!
The old systems were on Mac Pro 1,1's... HD3.... 16GB RAM Much much happier with HD Native on the 4,1's and 5,1's over HD3 on the 1,1's HD2 is gonna be pretty lacking for any kind of standard work by today's standards.... HDN spanks HD2... and for many situations even HD3 Anyway..... if I were you, I'd look into HD Native and a 4,1 or 5,1 Also, I'm not moving one room off HDN onto Waves SoundGrid (for studio, and live application) Both are great solutions and worth looking into. SoundGrid also has DSP server options
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
D-Show system with power sequencer/relay system. | TheatreWeasel | VENUE Live Sound Systems | 2 | 01-15-2012 03:35 PM |
Current System Limitations | Mixchump | Pro Tools TDM Systems (Mac) | 12 | 11-27-2010 07:24 AM |
Mix system i/o limitations | Tal | Digidesign Hardware & Software | 5 | 07-04-2009 08:16 AM |
Power supply limitations on MBox 2 USB vs. MBox 2 Pro | Jongman1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-20-2007 04:08 PM |
Running out of CPU power | nobby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-11-2001 01:10 PM |
