  #101
Old 10-12-2011, 12:57 PM
Default Re: Pro Tools 10 looks great!!!
Originally Posted by Emcha_audio View Post
let me ask you a question then, room reverb aside, when you play the instrument, is there leakage of the instrument on to the other tracks? Example, if you play the tuba or tubas, do you hear it on the violins? (which shouldn't happen at all in a VI ) If no then it's possible to convert your stereo track to mono. You might lose the proper positioning from the conductor, but then again you can gain it back by proper pan positioning.
You wouldn't hear another instrument because these libraries were recorded such that each instrument in the case of a solo instrument or groups of instruments as in a violin section, for example, are the only instruments playing.
When the orchestra is playing as a group then yes, you would hear other instruments in spot mics if you've got mics with almost anything other than a cardioid or hypercardioid mic. It all comes down to proper mic techniques. Perhaps your questions might be better taken up by the people at VSL or LASS who actually make these libraries.
Besides - what do you have against stereo tracks? Why not use what a library maker gave you in the way they expect it to be used?
  #102
Old 10-12-2011, 01:39 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
That's exactly what I'm saying. Since you don't hear the bleeding of the other instruments in the mics, because it's a VI, then you can simply convert each track to mono without problem.
Quite simply, you get more tracks to use that way, and in all truthfulness, beside the room mics, the instruments would be mono anyways. I'm giving the guy that uses his 88 tracks constantly due to the VI other options here. Using a stereo track for a mono instrument is a waste of resources.
Manny.
Wave-T.com
  #103
Old 10-12-2011, 01:49 PM
DarylG DarylG is offline
Vienna Instruments are not mono, in spite of what you may think. There are some instruments that you can narrow the stereo width of so much that they almost become mono, but trying to make most of them mono is a disaster waiting to happen. There are no room mics. There are no spot mics. You get one sample, which (I think) is a combination of all the mics used for recording summed to one, stereo instrument.
D
ProTools 9.02
2 x Intel Xeon x5675 3.07GHz Hex Core
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
ATI HD5400 series graphics card
  #104
Old 10-12-2011, 02:04 PM
D
Yes well that's due to the actual room mics being combined with the spot mic into the sample. Cause when you mic a violin, tuba or any other instruments of the kind, with the exception of piano, drums, stereo guitar pedals, harp. You usually use only one mic on it, then place room mics to get the room ambiance and stereo imagine for ensembles. Which you already know of course. By it self the instrument is not stereo which is what I'm saying. Now wither or not you have control on the room mics, that depends on the libraries. But if you are only using one instrument sample you can do what I said and save on the resources.
I'm not 100% sure since I wasn't there at the recording of the samples. But most of the time, unless they are doing ensembles, it's one instruments placed in the studio with multiple mics, without actually placing the instruments in the position they would be when they are playing as a whole orchestra.
Manny.
Wave-T.com
  #105
Old 10-12-2011, 02:23 PM
When I was using the Gigastudio version of VSL Cube I did convert some of the instruments to mono, but I do think that it was at the sacrifice of some of the sonority. I'm no longer prepared to do that, just so that I can mix in Pro Tools. For me it's one compromise too many. Workarounds are OK, providing that they don't take too much extra time, but when the actual product starts to suffer, that's where I draw the line.
My current project is relatively small, so track count won't be a problem, but the one after that will have to mixed in another program, because Pro Tools really isn't up to the task.
Mind you, who knows what PT 10 will bring, so by the time that I'm ready to mix, things may have changed. Who knows? Avid does, that's for sure.
D
ProTools 9.02
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
  #106
Old 10-12-2011, 04:45 PM
zedhed's Avatar
zedhed zedhed is offline
It's interesting that everyone is focusing on talking about the benefits 64Bit would bring to using VI's when that is only one of the advantages of a 64Bit system and probably not even the biggest advantage.
Being able to load larger parts or even a whole program (hell maybe even two) into the virtual memory of a system will mean a much smoother & faster workflow. So for professional studios particularly, this will have a huge impact. Whilst the first version of PT10 may or may not have that full capacity to start with, it is the direction modern computing is heading.
Now that 64Bit operating systems are gaining consumer momentum, the motherboards aimed at the consumer market are increasingly upping the ante with it not being uncommon to see mobo's with 128GB+ RAM capabilities already on the shelf. Most surprisingly systems with that capability are relatively cheap, at least for those who are capable of stitching a computer together themselves.
Those who don't see 64Bit programs as a big deal are speaking purely out of ignorance in not knowing how much of a potential improvement, not just to Pro Tools, it will bring. I say potential because it depends on what Avid/Adobe/Microsoft etc do with their own programs.
For me personally, PT10 is probably the most eagerly anticipated version because with the latest technology it has the potential to take a quantum leap into the future. I can only hope that Avid recognizes it and seizes the opportunity.
Judging by the link noiseboyuk provided earlier in this thread, they look to be on the right track.
http://www.youtube.com/watch?v=8ez-G...e_gdata_player
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
  #107
Old 10-12-2011, 05:37 PM
Bleed from other instruments has NOTHING to do with whether a sample or track is in stereo so your argument is moot at best.
  #108
Old 10-13-2011, 01:47 AM
The RAM disc thing is not much use to me, but if I am using multiple reverbs, the amount of memory used by the IRs, together with used by copious automation, does get rather large, so in that case 64bit could be very handy. Mind you, when VE Pro 5 comes out it this will be less important, because I will be able to host the memory hungry plugs outside of Pro Tools.
I wonder whether we will end using such a large amount of memory. The amount of time that it would take to load is enormous, and I think that for many people SSD would be much more convenient. Not only would things load faster, but in the case of Virtual Instruments the pre-load buffer wouldn't need to be anywhere near as big (in some cases) so the memory usage could be reduced, rather than increased.
D
ProTools 9.02
48GB RAM
Windows 7 (x64)Pro
RME Multiface II
Intensity
  #109
Old 10-13-2011, 05:53 PM
zedhed's Avatar
D
Once loaded into memory though, there would be no need to flush so it would remain loaded, that is if is designed as a program to do so.
HD 96I/O
[IMG] code is Off
CPTK 2 with 2008 MP, great. PT 11HDX with 2012 MP, not so great. Switch drive? Christer-André Pro Tools HDX & HD Native Systems (Mac) 2 02-04-2014 01:16 PM
pro tools 10 is great but... AxeDye Pro Tools 10 5 10-26-2011 09:45 PM
URS Plug-ins - Great Sound, Great Service rockrev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-18-2004 09:27 AM
A great new Pro tools book... protoolsuser Tips & Tricks 35 02-02-2003 06:50 AM
Digi and everyone - I've got a great idea for a great new feature [Benjamin] Tips & Tricks 65 10-13-2002 07:26 PM
