  #21
Old 03-20-2020, 04:07 PM
the.engineer the.engineer is offline
Default Re: CPU spike and errors on PT Ultimate/HDX system
Originally Posted by arche3 View Post
The drive error then making the crashes right?
Well, I think so. As usual in my unscientific way I changed so many things at once it could be the culmination of a few things.
My initial issue was -9093 errors: one usually every time Pro Tools opened. I had hyperthreading turned off as well.
I disabled spindump, this stopped the 9093 but then I got "Can't get audio from the drive fast enough" even though I was using Disk Cache. Then my audio drive disappeared completely due to a Raid disk failing.
So, moved some sessions onto a temporay 512GB SSD and all is well.
Mysteriously along the way, hyperthreading seems to have turned itself back on again...
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #22
Old 04-01-2020, 02:06 AM
smokeydan smokeydan is offline
Originally Posted by Will Russell View Post
FWIW I have not identified Altiverb as a source of spikes on my system.
Interesting. We don't have any Sonarworks here.
To be clear, I can have several instances of Altiverb on Aux Tracks, no problem. But if I then insert even one instance on an audio track, the sessions won't run reliably below 512 buffer, even on a session with just a couple of tracks and no other plug ins.
Audio ease were able to replicate this issue at their end two years ago, but have not released an update since.
Mac Pro 5,1, 2 x 3.46Ghz six core Xeon, 64GB RAM, Mojave, PT Ultimate 2022.10, H/D Native PCie, Avid Omni interface.
Mac Pro 6,1 12 core, 64GB RAM, Catalina, PT Ultimate 2022.10, 2xHDX cards & UAD Octo PCIe card in Sonnet TB Chassis, 2 x Lynx Aurora 16 interfaces.
MacBook Pro 32GB RAM Catalina, PT 2022.10, UAD Apollo X4
A TON of spike and errors with 12.8 9093/72 [email protected] Pro Tools 12 38 06-29-2017 02:54 PM
Buffer Errors (6086 and 9128) using Komplete 9 Ultimate Instruments dunnaj Virtual Instruments 0 05-29-2013 12:14 PM
Windows 7 Ultimate Freezing and BSOD Errors! terrencej31 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-13-2012 05:05 AM
Processor spike & system freeze-up is sessions psalmeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 04-25-2010 04:40 AM
Multiple blue screen errors when trying to install/run PT 8.03 in Windows 7 Ultimate WorshiperDj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-14-2010 02:50 PM
