Old 03-11-2020, 11:28 AM
iljunegate iljunegate is offline
Default hdx pro tools 2019.12 driver issue osx 10.13.6
Hi everyone,
I have a 2012 mac pro with high sierra 10.13.6 and pro tools hdx ultimate 2019.10
Everything has always worked perfectly until a month ago. Random problems started, pro tools no longer saw the hdx card and crashed randomly. I state that when the problems started I had not made any changes to the system. So I immediately thought about hardware problems to the card. To remove all doubts, however, I made a new installation of the operating system on a new SSD by installing only and exclusively pro tools. Magically everything went back to work. Luckily it wasn't a hardware problem.
I armed myself with patience and started to reinstall the whole system and all the plugins I work with. After installing the native instrument komplete ultimate… the pro tools hdx driver has not started working again.
I think I found a solution by excluding the NIHardwareAgent and NIHostIntegrationAgent from Mac boot starting, but I'm not sure is the final solution. I have to check if the system works the first time next days
My question however is: how is it possible that two company as famous as avid and native instruments could have such a level of bugs and undocumented incompatibility? I have searched everywhere and it seems I’m the only one to have this problem. I'm going crazy and nervous…
I hope someone can enlighten me
Thank you
Mac Studio M2 Max 64gb ram 2tb
Monterey (last version)
Pro tools Ultimate 2023.12.1
Avid HDX card | 2x Avid HD I/O 16i/o | Avid MTRX studio
Api 1608 | Avid S1
Dolby Atmos certified 7.1.4 with Amphion Speakers
Old 03-11-2020, 12:21 PM
Default Re: hdx pro tools 2019.12 driver issue osx 10.13.6
quick update: after some restarts nothing changed. So I think NIHardwareAgent and NIHostIntegrationAgent are not the problem.
I tried everything! please helppppp
Api 1608 | Avid S1
Old 03-11-2020, 01:12 PM
martthie_08 martthie_08 is offline
can you run Digitest?
did you do the reinstall on the same SSD?
If so, I myself would try to clone the system to a new harddrive, uninstall ProTools and HD Driver and reinstall them..
Old 03-11-2020, 01:16 PM
Yes I’ve done that and nothing.
Now I’ve reinstall everything from scratch on a brand new ssd.
But I have the same problem after install native instrument.
Before that it worked.
The digitest start only when the driver works. When it starts everything is ok. When the driver have the issue I try to start the digitest but it crashes
Api 1608 | Avid S1
Old 03-11-2020, 01:20 PM
what about 2019.6 - have you tried installing that? (along with the corresponding HD driver)
Old 03-11-2020, 01:30 PM
No but I wanna try. The problem is I can’t find the installer
Api 1608 | Avid S1
Old 03-11-2020, 02:11 PM
you'll have to link your AVID account to the download center.
Then you have access to all the previous installers.
Old 03-11-2020, 02:15 PM
Thank you...
What or where is this “download center” ?
Api 1608 | Avid S1
Old 03-11-2020, 02:43 PM
Search google avid download center..
Old 03-11-2020, 02:47 PM
Thanks. I hope it will work with 2019.6
Anyway I pay A LOT of money and this setup is 100% compatible...
Is totally unacceptable having all these problems.
Very frustrating
Api 1608 | Avid S1
Avid HDX Driver issue Pro tools 2019.12 iljunegate Pro Tools HDX & HD Native Systems (Mac) 0 03-11-2020 10:45 AM
Avid 2019.6 HD Driver & OSX 10.15 LDS Pro Tools HDX & HD Native Systems (Mac) 1 10-17-2019 07:34 PM
uninstall issue with pro tools 10.3.3 and interface driver Californiakeyz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-22-2018 02:27 PM
Pro Tools 10 install issue (HD Driver x64 missing) ? ionactive Pro Tools 10 2 01-04-2013 01:55 PM
003 Driver Issue With Pro Tools 9 asaffulks Pro Tools 9 20 05-26-2011 06:49 AM
