Old 03-20-2005, 12:43 PM
hotstuff hotstuff is offline
Default Phantom power and mic with power supply?
Hi all!
I have a problem, I want to use the M-S recording technique with my octane preamp, caus it has this feature, with a Rode K2 mic and a AKG C3000b, but the AKG requires phantom power and the K2 has a power supply and the preamp will only put phantom on both channels at the same time! Will the phantom power harm the power supply of the Rode mic? It doesn´t say in the manual if you can use phantom with the mic pluged in.
Old 03-20-2005, 12:56 PM
KingFish KingFish is offline
Default Re: Phantom power and mic with power supply?
You should be fine, the only mic's you have to be EXTREMELY carefull not to put on a phantom bank, are ribbon microphones.
Dynamic mics, and Tube Mic power supplies will ignore the 48vdc.
However, an improperly wired mic cable, carrying phantom can blow up a condenser.
David
- MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3
- HDX II Sonnet xMacPro Server
- 16x16 HD i/o x 6
- PT 2018.10
- OS X 10.14.4
- ProTools Dock / PT Control
Would this UPS (Uninterrupted Power Supply) protect and power my gear? D_Japan macOS 4 07-24-2011 04:23 PM
Control24 Phantom Power Supply Pins Nicolasixxx ICON & C|24 2 04-15-2010 02:28 AM
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
recording with phantom power *and* without phantom power simultaneously SweetSoulSound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-22-2008 07:40 PM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
