Old 09-02-2018, 08:02 PM
Tommyprotools Tommyprotools is offline
Default Protools 9
I am thinking of staying with my Pt9 that I bought years ago and get a new laptop with windows seven to run it. Is the quality that much better if I was running the latest Pt12? Also, all the money I have into plug ins and vst’s(komplete8) would be lost if I upgrade my Pt9 to a Pt10 or 12. Any thoughts from people running older Pt9,?
Old 09-03-2018, 12:42 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Protools 9
I don't think you will notice a real quality difference between 9 and 12, but you will have many more features. The latest version is 2018.
You wouldn't lose your Komplete 8 plugins, but depending on the versions you have there may not be AAX versions available. You would probably need to upgrade to Komplete 9, I think that's the version that added AAX to everything. Since you have K8, you can upgrade to K11 for $199
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 09-03-2018, 01:21 PM
Thanks Brian for the quick response. I think I will try staying with Pt9 for now and I can always upgrade down the road 😀
Import session protools 8 mp vers Protools 12 [Résolue] eryck Le Forum en Français 5 10-18-2016 11:54 AM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
Protools 8 m-powered unavailbe license after instal protools 11 Melle279 macOS 4 09-27-2014 08:05 AM
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
