  #21
Old 09-05-2018, 03:52 AM
Ru_C Ru_C is offline
Default Re: 10.13.6 with 2018.7 ... best version ever!? Holy Sssh
Originally Posted by skylinepro View Post
OS 10.13.4 has been a glitchy nightmare for both 2018.4 and 2018.7. After seeing enough folks here willing to take the plunge with 10.13.6, I installed it tonight. VOILA! GLITCHES GONE! Buffer 32 works fine at 48K/24. I had to use 128 before to be stable. Hey Avid, send out an advisory! I shouldn't have to find out by cruising the DUC.
10.13.6 WORKS.
Hey Skylinepro, can you *record* at least a pair of tracks at 32buffer on a full session? That's where my machines went cpu-spike-crazy (OS 10.12.6) unless I closed down the edit & mixer windows. Playback was never an issue even with big sessions.
Fantastic if you can?
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
  #22
Old 09-05-2018, 12:20 PM
xrekcor's Avatar
xrekcor xrekcor is offline
I see there is another sup update 2 for HS 10.13.6 for the touch bar by the looks. I consider I went first when I installed the first sup before I first tried installing PT a month ago with no hassles.... anyone else keen to go first this time?
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
  #23
Old 09-07-2018, 05:52 AM
jkess jkess is offline
I am really tempted to give this a shot. I have CPU spikes more often with these latest builds than I did three or four updates ago. I checked it out and my computer (5,1) needs a firmware update to make the jump to 10.13.6 so moving back could be a huge pain the arse. Can Avid make an announcement about 10.13.6 please?
  #24
Old 09-07-2018, 06:12 AM
KV626's Avatar
KV626 KV626 is offline
You mean potentially downgrading to Sierra for example? Not a problem at all. I've had the new boot ROM for a while now (MP51.0089.B00) and reverted back to Sierra without any trouble. I am now back to High Sierra and both OS performance and PT's are great. Note that Mojave requires this boot ROM for installation, also you need an EFI gpu for the firmware upgrade, so you might as well do it now - totally harmless.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4
Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control
NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc
  #25
Old 09-07-2018, 07:09 AM
arche3's Avatar
arche3 arche3 is offline
Wow. This works. Shocked. Just so happy it finally works.
  #26
Old 09-07-2018, 11:06 AM
jsbach jsbach is offline
Originally Posted by TNM View Post
Very strange Avid's page says to still stay at 10.13.3 when even support have confirmed to me that 10.13.6 was fixed in 2018.7...
Please Avid update your system requirement pages :)
Cheers
Does that mean that we are technically using a 'qualified' system if we upgrade to 10.13.6? Would Avid still offer technical support?
I badly want to try the update. I really wish Avid would officially qualify it!
  #27
Old 09-07-2018, 11:35 AM
JFreak's Avatar
JFreak JFreak is offline
Me too, without the "finally" ...
I've probably ran every single PT version out there since PT 6.0 on OSX but you need to always clone your "working" drive so if things go south you can revert by simply cloning back. Or to have multiple partitions, as I had when I was in the beta team.
Never ever rely on one single booting drive if you depend on your tool
Janne
  #28
Old 09-07-2018, 11:36 AM
JFreak's Avatar
I've escalated the question regarding 10.13.6 qualification but as always we get a word when the process is done :/
Looks good though, no glitches here.
Janne
  #29
Old 09-07-2018, 11:41 AM
I'm running Yosemite still 10.11.6. Will the firmware update allow backwards compatibility that far?
  #30
Old 09-07-2018, 02:32 PM
xrekcor's Avatar
when I got my MBP last month it came loaded with 10.13.6 and I contact Avid before I installed 2018.4 (at the time) they were very happy to offer tech support even though 10.13.6 isn't supported. the installation went hassle free apart from the noted buffer error. the buffer error has gone since 2018.7 albeit it might pop up once a week, I usually change nothing and I don't see it again. but that is my experience.... seems pretty solid to me now. I can only assume that Avid is prolly aware that some users have experienced a bug fix but and are yet to satisfy themselves (probably against a set of conditions)
my greatest apologies ill never try to be funny here again..... regards
Rob
Is Pro Tools 2018 EVER going to be supported on a current Version of High Sierra? off the wall macOS 10 01-05-2019 04:53 PM
Macbook Pro 2018 w/ UAD Apollo 8p and PT 2018.7 Performance Issues Dudiester Pro Tools 2018 5 08-12-2018 08:33 AM
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
Permission Denied (13) on Launch -Pro Tools 12, Version 2018.1 Randroo Pro Tools 2018 7 05-07-2018 08:11 AM
Does the 2018 boxed version come with iLok 2 or 3 and ... rique000 Pro Tools 2018 3 02-23-2018 06:11 PM
