Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 11-30-2013, 07:41 AM
MartinoAl MartinoAl is offline
Default External Hard Drive for PC Laptop
I am running Pro Tools 8 and have been putting off getting an external hard drive but now need to sort as my Acer PC laptop hard drive is getting full. I have been doing a bit of research (and feeling confused) and was thinking the following looked good. Before I take the plunge, could someone confirm that this will be suitable to work from and record onto:
http://www.amazon.co.uk/Avastor-exte.../dp/B0015U83FI
If anyone has a better suggestion, please let me know too..
Thanks,
Martino
Old 11-30-2013, 08:05 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: External Hard Drive for PC Laptop
Way too much money for that my friend !!!!!
This is a good one
http://m.newegg.com/Product/index?it...82E16822178105
Only 89$ which is about £100 or so
Daniel
Old 11-30-2013, 11:04 AM
This is a good one
An no, sorry they are cheap and nasty crap. I am pretty sure the Seagate STBU1000101 contains a 5,400 rpm drive. Likely with Seagate "green" features as well. I definitely would not recommended these with Pro Tools, or for just about any other use. If a vendor does not proudly state the drive is 7,200 rpm it's for a reason...
I would look for external drives from manufacturers like Glyph, G-Tech, OWC or Lacie. But even then you have to make sure the HDD is at least 7,200 rpm. Avastor is another brand that DAW users will use. With any of these quad interface etc. drives you are paying for that, if you only need USB3 there is more to choose from but you need to look at the drive specs. Generally avoid external drives from Western Digital or Seagate. They seem convinced that the goal is to market their lowest-performance crap drives to consumers and try as hard as possible to obfuscate the actual performance specs.
Old 11-30-2013, 11:11 AM
YYR123's Avatar
Actually ur right - that happened to me recently - best bet buy a bare drive and assemble a case ur self
I also recently bought a Seagate enclosure $20 and installed a sata iii hard drive that I had extra - USB 3.0
Daniel
Old 11-30-2013, 11:41 AM
The other comment here is if you care about performance or just want better robustness than a HDD then go SSD. There are choices there from Lacie and others, or install a Samsung 840 Pro or Evo SSD. in an external USD3 caddy.
e.g. I would buy this any day over the external HDD first mentioned..., http://www.amazon.co.uk/gp/aw/d/B009HQKQMA
or see the similar 256GB version.
Question about laptop and external hard drive jmbtexas Storage Subsystems 0 01-22-2013 03:50 PM
Laptop not recognizing external hard drive RichrdC Pro Tools M-Powered (Win) 0 02-21-2010 09:18 AM
Laptop firewire & external hard drive question RichrdC Pro Tools M-Powered (Win) 2 01-05-2010 12:44 PM
Laptop, Lightbridge, External firewire hard drive wildplum Pro Tools M-Powered (Win) 4 02-11-2008 11:16 AM
Best way to connect laptop to Digi, external hard drive? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2007 07:31 PM
