Old 02-24-2016, 05:02 PM
stanonbass stanonbass is offline
Default how to make c24 work in windows 7 and protools 12.
1. Go to control panel. Make icons big.
2. Select Network and Sharing center
3. Click change adapter settings
4. Right click local area connection and select properties
5. click install and select protocol
6. click have disk
7. click browse and go to c:\program files\avid\pro tools\Ethernet Support
8. Click diginet and press ok. avid icon and c24 support protocol is there and press ok again.
Now it will work in protools 12!
Old 04-24-2016, 10:45 AM
Jason Grooms Jason Grooms is offline
Default Re: how to make c24 work in windows 7 and protools 12.
Thank you! Very helpful. Avid please make a note of this!
Old 04-26-2016, 08:05 AM
Gemylon's Avatar
Gemylon Gemylon is offline
I am not using the Control 24, but a friend of mine does ...
Any idea if this could work on a Mac ?
Btw ...
Very nice tip
Old 07-30-2016, 05:07 PM
RockFarm RockFarm is offline
I recently bought a C|24 and am unable to get Pro Tools (12 on Win 7 64) to see it. I tried stantonbase's method and it's still not seeing the ethernet. Will attempt a full reinstall of Pro Tools next. Are there any other recommendations?
Thanks.
Old 07-30-2016, 05:08 PM
Southsidemusic's Avatar
Btw ...
Very nice tip
This only works with C|24 not Control 24.
Best Regards
Christopher
South Side Music Group
WEBHOME
SOUTHSIDEPUB
Old 07-31-2016, 02:10 AM
8dB.co.uk 8dB.co.uk is offline
6. click have disk
This is the same as getting a D-Command to work on PT12 / Win10. For some reason the Pro Tools installer doesn't do it.
Sent from my D5803 using Tapatalk
PT12.4HD, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 64bit Pro, BM Mini Monitor PCIe, GTX 660Ti,
& MacBookPro, OS-X 10.10.5, i7 2.3GHz 16GB
RME FireFace802 + ARC, Motu UltraLite Hybrid Mk3
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1 Presonus Monitors
Other systems I use -
Apple OS-X Yosemite, Win 7, PT10.3.5HDX, 11.2.2HDX, S6, Icon, AMS-Neve DFC, C24, M&K, Genelecs
Old 02-17-2017, 09:20 AM
paulmellors paulmellors is offline
I have same issue but this method didn't work for me. Any other suggestions? Does a full re-install fix it?
THanks
Paul
Pro Tools 10.3.2 C|24.RME Fireface 800, OSX.8.2 mac pro 20gb Ram, MacBook Pro 2.4ghz 4gb ram. McDSP plugins, URS Eqs, Abbey Road Chandler, Focusrite Forte Suite
Old Today, 03:02 PM
Resolved:
Windows 10 will uninstall the Avid driver for ICON/C24 because it is unsigned.
It looks like it is installed in the network adaptor, the protocol is ticked, but it is actually uninstalled.
To install you MUST disable secure boot and keep it disabled. This allows the driver to be installed and the C24 works perfectly.
Does protools 9 work on windows 8? yorgo Pro Tools 9 Discussion 2 12-13-2014 10:37 AM
Windows 8 PT 10 conflict. Trying to make it work. martyredwhitmans Pro Tools Software (Win) 6 02-13-2013 06:24 PM
Protools 7.4 And the HP 8710w. PLeassssse make it work lol gregers123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 09-17-2008 03:06 AM
Deleting files to make protools work better willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-18-2008 07:02 PM
Help ... Does Protools 5.3.3 work with Windows XP? scottely 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-22-2006 11:33 PM
