#21
Re: Pro-Tools Sabotaging My Projects!
+1. I always use "show full path". Anytime I open up the clip list, I want to know exactly where the file is located. Also, it's a great way to make sure everything is stored where you think it's supposed to be.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
#22
A lot of people working at avid are actual musicians and have spent time in studios. I would personally try to refrain from making such assumptions when you don't know the people. As my dearie wife says, making assumptions makes an ass of you and me. |
#23
As suggested earlier, here lies your problem. This procedure results in a PTX file that writes all its audio to the audio files folder in the folder inside the templates folder. You must open the template, "save session copy…", close template, and open newly created.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
#24
I’ve discovered the source of the problem. Coming up with a solution is going top be tricky, though, because it involves finding a workaround for a behavior so bizarre, a person would have to intentionally, purposefully author a software to include something this astoundingly stupid.
The image I attached shows yet another project with missing session clips. Like almost all the others, the missing clips have mirrored, counterpart clips that weren’t deleted. By “mirrored,” I mean these guitar tracks are recorded as both mic and DI tracks—two tracks—simultaneously. Only one of the two-track pairs is missing, though. That’s because Pro Tools has been randomly saving some clips to the Audio Files folder in the actual project folder, and others to another, foreign Audio Files folder, nested inside a Pro Tools Projects folder it created on my root directory. I came across that isolated, root level Pro Tools Projects folder last week, knew it shouldn’t by any reason be there, and assumed it was a remnant of some recent restructuring I had done on my file system. I did a system search on a few of the files, found them to be duplicates, and felt comfortable deleting the folder, since there was no PTX file associated with it. That folder, however, was holding all those clips that have been coming up missing in projects, projects also showing an Audio Files folder within project folder, with other audio files in them. Just this morning I found another, newly generated, root-level Pro Tools Projects, with more random audio files in the Audio Files folder, and made the connection to this problem. I know there’s a feature in PT called “Round Robin”, where, “Pro Tools will automatically distribute any newly created tracks around all of the drives connected to your system...”. Whoever the complete idiot was who thought that was a good idea—separating audio files from the project folder and scattering them far & wide throughout the system—I have never heard a more concise definition of Recipe for Disaster. That disaster has happened to my files. But get this: Round Robin is not and has never been activated either globally or project specifically in my system. So how does this happen? The bottom line question is: how does a person safeguard his projects from a software that seems designed to to seek out and destroy the very projects it’s being used to create?
Pro Tools Studio, 2023.3.0 Mac OS: Ventura 13.4 System: Mac Studio 2023, Apple M2 Ultra, 128GB Unified Memory 2TB Internal SSD Apple Studio Monitor, 27" 3 External Monitors: 27", 27" & 65" Apollo X8P Mixer Interface PreSonus 32R Mixer Interface |
#25
This sounds to me like another problem brought over from the way you are creating your sessions by copying an existing session and renaming it. This is the whole reason the save as template exists, and so far it sounds like creating a sessions template, then opening pro tools, creating a new session from template will get you everything you want (track names, auxes, routing, etc) but will also update disk allocation settings and other details specific to each project that you are not updating when you copy and open up an existing project. The session template feature is really worth your time to explore more.
Open your blank session you are using as a template and check the Disk Allocation settings, then also open a project missing clips and check the Disk Allocation setting there too. Pro Tools will create a "Default" Audio Files folder in your home folder if it cannot write to the Audio Files folder set in the Disk Allocation setting. There can be several reasons for this happening, including a drive being seen as read only when a session opens. I wouldn't jump to the conclusion so fast that Pro Tools isn't operating correctly, there is probably something else causing the behavior. While you may not have a use for Round Robin, it's not an idiotic feature, but with SSD's and faster drives there is less need for it these days.
https://wanderingear.net |
#26
I think in my post on the first page I recommended you take a look at your Disk Allocation. If you must use the workflow you're suggesting (which is definitely not recommended), then you *absolutely* will have to religiously check Disk Allocation every time you start a new session. While there are things I'd love to change about ProTools, in the 20+ years I've been using this software I've never (knock wood) lost an audio file or project. Certainly there are tens of thousands of us using this software every day in mission critical applications who do not have these issues. I'd suggest you get a handle on disk allocation.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 Last edited by Rich Breen; 02-22-2019 at 10:12 AM. |
#27
User error. Like I suspected. Well maybe not pure user error. But the session setup has some potential for stuff like this.
Have you tried a new record drive to rule out disk hardware error? Sent from my SM-G965U using Tapatalk Last edited by arche3; 02-22-2019 at 10:14 AM. |
#28
If you want a solution, learn to use the import session data function AFTER you create a new session for each of your projects. Shft+cmd+I.
This way you can import all the tracks, names etc without also importing the settings of where the audio files are stored or the audio from the other session. If you were to read the manual, you would that all of this is fully covered. |
#29
Don’t assume that you can perform functions with pro tools sessions in Explorer or the Finder and it not have an affect on how pro tools relates to those sessions. Create a session on drive A. Record many tracks and save. Copy session folder to drive B. Open session on drive B and record many more tracks. Those tracks will be put in the audio files folder on drive A if the original session paths are still valid. If you delete the session from drive A before opening it on drive B, Pro Tools will update the file locations when opening the session on drive B. That’s how Pro Tools works and that’s why some of your files were being put in a place other than the session folder of the session you had open. Copying and renaming a session still leaves the original paths intact. If you want to manage media locations, it’s best to be done in Pro Tools, not outside of it.
#30
Is round robin still a thing? Ew.
sent from a stupid phone using Tapatalk |
Missing fade files, missing audio in resaved sesssions | drygruo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2010 04:56 PM |
All Sessions using SDII files are missing all audio files and won't relink | bigmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 03-18-2009 12:54 PM |
missing audio files are actually not missing | tomcat | Pro Tools TDM Systems (Mac) | 3 | 12-24-2006 02:25 PM |
Fade Files as Audio Files in "Missing Audio" ?? | CCash | Pro Tools TDM Systems (Mac) | 6 | 05-18-2005 09:00 AM |
Missing Fade files become missing audio files? | Tim R. | Pro Tools TDM Systems (Mac) | 11 | 06-21-2004 09:48 AM |
