#21
Re: Anyone else with slow graphic redraws in 2018.1
2) or are you using VI's ??
#22
Just to add an alternate view, all my monitors are run at their native resolution, so UHD or 4K, and usually with an HD HDMI output. Fortunately I haven't experienced the Graphics Slowdowns.
System is: 2013 MacPro, lowest model, 12GB ram, standard Graphics Card. PT HD Native, MacOS High Sierra Sessions are usually quite large, 200+ tracks/busses etc, but minimal Virtual Instruments. |
#23
Update to my unscientific "stress-test": I've got 240+ MIDI tracks going now, and there is a bit of a drop off in responsiveness (momentary hangs in the edit window and track list), but nothing like the crippling extent it was at before. After the brief hangs, scrolling and selecting tracks is quite responsive.
Last edited by fixxer49; 02-11-2018 at 02:22 PM. Reason: clarification on VEP instances |
#24
Update:GUI responsiveness (or lack of responsiveness) issues have returned!
I did not touch the session since my last post - just let it sit for a while. What could be causing this to happen? UPDATE: closing and reopening session has [temporarily?] solved the problem. i also quit all the avid app manager apps and the quicktime server function. I'm going to let the session sit for while and see what happens now.
#25
QT server, i think you just have to quit that every time you restart your computer ..
#26
After quitting and re-opening session (not shutting down my system, just quitting and restarting PT), everything is snappy again. MIDI track redraws are pretty much instantaneous (about 50 - 60 tracks at a time.)
#27
That sound like a memory leak....historically speaking. I have no empirical data to back that up....
What happens when you run The session without VEPro? Load as many VI’s as you can and test, then let it sit and come back and see how it responds
#28
Something else then. I wish we knew why some people with identical macs have graphic slowdown and others not. After reading every graphics slowdown thread i really thought the common denominator was UHD and AMD. Sorry about that. I do know the only thing i changed to a standard install is stopping app manager from booting with mac by modifying the launch plist file, but i haven't uninstalled cloud services this time. I haven't had a graphics slowdown issue since el capitan and PT 12.6 through 12.8.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
#29
It could be a rogue plugin in VEpro. This was happening to me with hornet magnus mk2. All i did was have one instance on the master fader.. after about 20 minutes my free ram had almost disappeared and things DID get impossibly sluggish. Your post triggered the memory and it took ages to work out by process of elimination. (i believe the dev has fixed the leak in the plugin after i reported it, so don't let this put you off his plugins or anything). There are heaps of free memory apps on the app store, perhaps the OP could install one and check free memory at time of slowdown, and then hit the memory clean button to see if it temporarily fixes the issue. Or it's possible he is simply just using all that memory with all the VI's.. I do know that every time my free ram gets under the 500mb mark here, safari becomes terrible to just click and activate a tab, and in general the OS becomes very slow. So i think you might be on to something!
#30
(Also - i'm not the OP, but i guess I've hijacked this thread.)
Pro Tools HD 2018.1 - Preferences & I/o VERY slow to close | DrFord | Pro Tools 2018 | 4 | 01-26-2018 04:27 PM |
Slow Screen Redraws when multiple plug-in windows open | PatrickCusack | Pro Tools 12 | 2 | 12-09-2017 05:05 AM |
Half-arsed solution for slow screen redraws | ecalcagnino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-08-2003 12:16 AM |
Slow fades, redraws on NuBus PT3 | Steve Cohn | Pro Tools TDM Systems (Mac) | 0 | 07-12-2000 10:58 PM |
Slow screen redraws with quicktime | Xantar | Pro Tools TDM Systems (Mac) | 3 | 04-04-2000 04:23 PM |
