#81
Re: Automation AppleScripts for Pro Tools (Mac)
#82
Unfortunately the script (app) does weird things on my system so I take it that it wasn't created for the public but personal use?! |
#83
I've forgot again to mention, that track list, clip list and all floating windows should be closed, and the Edit window and mix maximised.
I need to write a read me file eheheh. As you teach me, we can't get to know some settings if they are enable or disable, example, some radio buttons, and in this case the track list and clips list are showed or hidden. At least I didn't discover how to do it. I will update the project with some guide lines in a few minutes. Here is the new project .. download here
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 03-10-2016 at 02:54 PM. |
#84
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro |
#85
When creating scripts for personal use it is not necessary to think about things that could go wrong because the script creator knows what to avoid. Creating versions for public usage is a totally different ballgame as all kinds of checks (if/then/else etc. etc.) should be implemented, checks that sometimes are very hard or even impossible to achieve. ;-) I am curious, why have you opted for a click by position with cliclick for checkboxes like "Audio Files" and "Convert to Specified Format"? click checkbox "Audio Files" and click checkbox "Convert to Specified Format" should have worked just fine, without cliclick. And another little thing. Since you have created the variable "sessioname" already, you can pass this over to the text field of the Save window, like that: tell window "Save" set value of text field 1 to sessioname end tell So no need for all this key code stuff. ;-) |
#86
I'm trying to figure out what to do with this... I get what it does, but still not get where I can use it.. :/ Code:
tell window "Save" set value of text field 1 to sessioname end tell One thing that I've managed to do is pass at least the error of people let the track list open and the script stop. Code:
try click button "Track List Show/Hide" tell button "Track List pop-up" --perform action "AXPress" of button 5 set {xPosition, yPosition} to position set {xSize, ySize} to size my cliClick("c:" & xPosition + (xSize div 2) & "," & yPosition + (ySize div 2)) end tell on error click button "Track List Show/Hide" end try
#87
Code:
set sessionName to "This Is A Test" activate application "Pro Tools" tell application "System Events" tell process "Pro Tools" tell window "Save Session Copy" click checkbox "Audio Files" click checkbox "Convert to Specified Format" click button "OK" end tell repeat until exists window "Save" delay 0.1 end repeat tell window "Save" set value of text field 1 to sessionName delay 0.1 end tell end tell end tell |
#88
NICEEEEEEEEEE I can use this for all the other windows too, Bounce, Export session info as text. NICE!!!! Thank you always learning that's awesome. Is there a better way to get errors? I used the try. I've used this: Code:
try click button "Track List Show/Hide" on error display dialog "Please close Track List" end try
Marco Bernardo Dialog Editor, Sound Designer, Re-Recording mixer nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro Last edited by Marco Bernardo; 03-12-2016 at 04:54 PM. |
#89
I used what you gave in conjunction with this script that I've found from another user And it could be "automatic" and it remove the Edit: from the name I know you know how to do it :) you're a master Code:
on lstripString(theText, trimString) -- ljr (http://applescript.bratis-lover.net/library/string/), modified from Aurelio.net (http://aurelio.net/doc/as4pp.html) -- this part of the script is from this guy local theText, trimString, x try set x to count trimString try repeat while theText begins with trimString set theText to characters (x + 1) thru -1 of theText as text end repeat return theText on error number -1700 return "" end try on error eMsg number eNum error "Can't trimBoth: " & eMsg number eNum end try end lstripString display dialog "Open a Pro tools Session and click ok - It will display the name of the session that you're working" activate application "Pro Tools" tell application "System Events" tell process "Pro Tools" get name of first window whose title contains "Edit: " my lstripString(result, "Edit: ") set sessionName to result display dialog sessionName end tell end tell
#90
How about this: Code:
tell application "System Events" tell process "Pro Tools" set editWindow to (1st window whose title contains "Edit: ") set editWindowName to value of attribute "AXTitle" of editWindow set sessionName to text 7 thru -1 of editWindowName display dialog sessionName end tell end tell |
Pro Tools 12 Trim Automation | [email protected] | Pro Tools 12 | 2 | 08-16-2015 04:25 AM |
Pro Tools 11.2.1 Automation Bug?! | Gneal550 | Pro Tools 11 | 1 | 11-22-2014 01:15 PM |
GRM tools automation bug? | D'Animation | Pro Tools TDM Systems (Mac) | 6 | 10-08-2014 08:21 AM |
scripting Pro Tools; automation | Bermaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-01-2004 12:38 PM |
AppleScripts and other Macros for PT | Bergeron | Tips & Tricks | 1 | 11-15-1999 06:55 PM |
