Old 10-10-2004, 10:09 AM
Communist Communist is offline
Default Few Noob Question.
I got a few basic questions that I need some help on.
1. Lets say im working on a session. I do the select unused/clear/remove "not delete" command on Audio Files that im not using on the session. Then I save session/quit pt. Would it be okay to manually delete the unused audio files from the session folder?
2. All my sessions are on my external HD. Would moving the Session Folder "by dragging" to different locations on that same external HD do any harm to my session?
3. Is it ok to delete the backup sessions from the session file backup folders?
Any help would be appreciated thanks guys.
M-Box Pro Tools LE 6.1.2 /PowerBook G4-867 Mhz-512 Ram /OWC Mercury Hard Drive/Korg Triton Classic
Old 10-10-2004, 11:39 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
Default Re: Few Noob Question.
That way you can manually delete since the files are no longer being referenced. If you just removed the regions from the playlist and not from the Regions menu, you will get an error saying it cannot find the region
This will force you to relink all the files afterwards when you reopen the session. Major PITA. You should use Save Session Copy In command to the new location and then delete the old session.
Yes. New ones will be generated if the auto-backup feature is enabled.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 10-10-2004, 01:19 PM
Thank you very much.
Noob question.... :D Hotcrazyfruit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-09-2010 12:41 PM
Noob Question miketheman83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-23-2010 11:31 PM
HD noob question Chuck Fu Pro Tools TDM Systems (Mac) 3 01-25-2010 07:55 AM
noob question soundezign Aspera DigiDelivery 7 01-18-2007 06:58 PM
Noob Question Nicc24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-19-2005 08:46 AM
