Old 03-13-2018, 12:53 PM
BScout BScout is offline
Default Re: Auto mode only goes back AFTER stop
Originally Posted by pqlior@mac.com View Post
it always stays on PT and this one reverts to unlocked when computer restarts.
Reported the same issue in a different thread.
Pro Tools Ult 2018.4, HDX 3, MTRX, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.12.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 03-13-2018, 07:48 PM
EddieJones's Avatar
For those with Locking issue, can you help by checking the prefs.
~/Library/Preferences/com.euphonix.eucon.plist
Under these keys:
Root/Locking/0/HostID
Root/Locking/0/AppName
Root/Locking/1/HostID
Root/Locking/1/AppName
Root/Locking/2/HostID
Root/Locking/2/AppName
Look in here just before restarting and then again if it loses the lock
Old 03-13-2018, 10:03 PM
pqlior@mac.com pqlior@mac.com is offline
Under these keys:
Thanks Eddie, will check.
Lior
HD Native * PT 12.8.1 * OS X 10.12.5 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble 6.0.16.778 * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 3.7.0 *
Old 03-16-2018, 07:16 PM
Wanted to report that original problem is NOT resolved in this update.
Lior
Old 03-16-2018, 07:53 PM
Zero problems here switch auto modes while in playback. Happens immediately. Tried it from the Dock, Control app, and Artist Mix.
I don't know if this helps since I'm not sure where you are triggering this from, but once I had an issue where fader moves wouldn't happen until the transport stopped much like your auto mode doesn't change. My case it happened from the Artist Mix. On a whim, powered down the Artist Mix and powered it back up and it's never done it again. So maybe cycle the power of your problem device (or if it is the ipad, give the ipad a restart and reopen Pro Tools Control.)
Old 03-16-2018, 08:34 PM
Originally Posted by BScout View Post
Zero problems here switch auto modes while in playback. Happens immediately. Tried it from the Dock, Touchscreen, and Artist Mix.
I'm on iPad control app and issue has not been resolved.
Lior
Old 03-16-2018, 08:42 PM
So power-cycling the iPad did not help?
Are you still on 12.8.1?
As per this post
http://duc.avid.com/showpost.php?p=2472528&postcount=6
that may be why your issue isn't completely resolved.
Old 03-17-2018, 02:33 PM
As per this post
Still on 12.8.1 12.8.2 is buggy as hell over here...
Lior
Scroll behavior when you stop--stay where you stop, or go back to playback point? bashville Pro Tools 10 15 01-26-2013 05:56 AM
Auto back up pt 10.02 failed to back up!! ricci Pro Tools Software (Mac) 4 08-25-2012 08:28 PM
Stop after auto punch stamand Pro Tools M-Powered (Mac) 13 04-04-2009 02:29 PM
How to set Auto Write on Stop Mode??? a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-30-2005 09:16 PM
auto stop Artie Digidesign Hardware & Software 4 02-04-2002 08:30 PM
