Trying to reduce all fader levels in 002 6.4 WIn
Trying to reduce all faders equally - pre-master. I select all (like it used to work) but all faders jump to 0db!
Can't find an answer. Any suggestions? |
Re: Trying to reduce all fader levels in 002 6.4 WIn
clear your automation
Cavell Studios |
Welcome to Duc
select group ALL on left of mixer view them move 1 of the faders, they all should move equally, just keep in mind if you have vol automation it dont work the same. If there a way to move volume automation equally with the faders clue me in? |
Doh!
I had a track with automation on. Thanks |
Can't you select all, make sure you have ALL tracks on Volume display & use the trim tool. This should retain any automation shouldn't it, just at a lower volume. No?
Scott -
Can't get it to work in 6.4 - It must be me - Alshiad never fails. |
What doesn't work? I'm running 6.4 as well, all you should be doing is trimming all the volume levels lower. Make sure you're not using a fader, use the trimmer.
It works track by track - and retains automation - I just can't get all 22 tracks to reduce together.
I used to be able to CTRL/SHIFT with everythin selected - and all tracks on volume view - and pull them all down equally. |
Basically the same thing happened to me tonight. I just wanted to ride the volume of one group (4 tracks) for 3 words and it kept undoing my set volume faders and set panning.
soon to be back at it again... |
I'm pretty sure this has worked for me, I'll try it out tonight & let you know...
CP650 fader levels | mr.armadillo | Post - Surround - Video | 7 | 02-07-2007 09:54 AM |
c24 fader levels not saved with 5.3.1 HD | Rail Jon Rogut | ICON & C|24 | 3 | 02-13-2004 07:12 AM |
Linking track levels w/ pre-fader bus levels? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-07-2003 10:36 PM |
Playback fader levels | Dead River Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-28-2001 12:59 AM |
What levels on master fader during mix! | DonCorleone | Tips & Tricks | 1 | 06-07-2000 04:03 PM |
