Kontakt Pro Tools Midi Controller Signal Routing
Hello Forum,
I'm having trouble monitoring my midi controller keyboard instrument while using Kontakt 2 as an RTAS plugin in Pro Tools. I'm using a Motif 6 as the controller and an M-Audio Firewire Audiophile. Here's my setup: -Stereo Instrument track with Kontakt 2 as a stereo multi-channel insert. The instrument I/O section is set to "All" input / Kontakt 2 1-1 Output. The track I/O section is set to Mic/Line input / Audio 1-2 Output. -One midi track with Firewire Audiophile Ch. 1 as input / Kontakt 2 1-1 output. When I play my Motif, I don't hear any sound, but I know that the midi signal is being picked up because when I record input from my Motif to the midi track, I see events, and they play back through the Kontakt plugin. Also, I've been able to monitor my keyboard playing through rewired Reason with no problem. I've tried record enabling both the midi track and the instrument track with the same result. Also when I play the virtual keyboard in Kontakt 2, I'm able to hear the sound. Just can't get my actual midi keyboard's signal to go through. Please help! |
Re: Kontakt Pro Tools Midi Controller Signal Routing
Hi
I think you need to check the Midi Thru option. It's on the Options menu. Paul |
That worked like a charm. Thanks Paul!
Kontakt 5 AAX Pro Tools 11 HDX Routing | fretfingers | Pro Tools HDX & HD Native Systems (Mac) | 22 | 03-20-2014 12:25 PM |
Routing MIDI channels in Kontakt directly from a Sampler | allen_gibberish | macOS | 0 | 01-26-2012 03:19 PM |
Kontakt / MIDI routing in PT | david_aka_mike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 07-27-2009 02:04 PM |
No Signal From my midi Controller To PT8.0 | V0X | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-22-2009 07:59 PM |
MIDI signal routing for an instrument plugin | Fletchmanxyz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-09-2006 08:49 PM |
