How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Old 10-09-2002, 09:06 AM
cdrecords cdrecords is offline
Default Recording midi and audio in sync
I've also posted this in the pro tools LE for windows forum as well.As Iíve experienced before Iím probably overlooking something very simple so I apologize up front. It is something Iím not seeing in any of the DUC though.
1) I want to use my drum machine connected to the 001 and monitored thru the 001 as a click and want to record a 4 bar guitar part.
2) Then I want to merge midi record a drum part that goes with the guitar part
Iím in low latency monitoring and in auto input monitoring
Buffer Size 128 samples
BPM 145
1 bar count off
I record the guitar part and play it back
When itís in record mode with auto input monitor the guitar part is in time with the click.
As soon as I take it out of record to go back and record the midi drum part the guitar part is late by 1011 samples
This led me to Global midi playback offset, which isnít helping. (Iíve tried many settings from
Ė10000 samples to + 10000 samples with no luck)
The guitar part is still late.
I appreciate any help. Thanks, Billy
Old 10-09-2002, 02:16 PM
Default Re: Recording midi and audio in sync
I realized after much trial and error that the Compressor and eq plug ins were the culprit. Once removed everything is in sync
Audio recording out of sync - Sandra Report Elnico50 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-28-2010 02:41 AM
Audio latency while recording durring midi sync adlib311 MIDI 1 02-25-2009 05:26 PM
Recording Midi sync problems?? please help luckylukedg MIDI 1 06-27-2007 10:27 PM
Recording Midi and Audio in sync cdrecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-09-2002 02:31 PM
How do I sync audio after recording? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-01-2001 08:52 AM
