Old 09-07-2015, 12:42 PM
mickeyrouse mickeyrouse is offline
Default Hardware sends issue
Can't tell if this for Pro Tools or Apollo, but here goes.
I am wanting to utilize the hardware outputs from Pro Tools via my Apollo Quad. I have several pieces of rack gear I'd like to use- UA 6176, Manley, Neve, Altec,and API compressors to just to name some plus various EQ's and noise gates. As I look in the output options in the I/O set-up in Pro Tools 11, all channels of devices that are connected to my Apollo appear: 8 Apollo channels, 4 4-710D channels, 2 S/PDIF channels. Yet when I attempt to send to any channel above the 8 Apollo channels, nothing happens.
Should it? Am I wanting to do something not feasible? Or have I missed something in the Pro Tools i/O set-up?
Mickey in Texas
Old 09-07-2015, 07:48 PM
Default Re: Hardware sends issue
Not sure if this applies, but....are you trying to use hardware inserts(track insert; out to hardware and back to the same track)? If that's the case, hardware inserts must use a matching pair of in/out(out #6 and in #6, out #8 with in #8)
Old 09-07-2015, 11:53 PM
I am using the pair matches satisfactorily on sends 1-8 thru the 8 channels of the Apollo outs. Though the insert window in I/O set-up shows that it is at least acknowledging the ADAT and S/PDIF units, clearly no signal is being sent.
Old 09-08-2015, 06:34 AM
...and have since realized that signal is unidirectional via light pipe ADAT to Apollo. Question settled pretty much.
Pro Tools Sends Issue bryced87 macOS 10 07-24-2014 06:35 AM
Hardware Inserts -vs- Sends Table Syrup Records Pro Tools HDX & HD Native Systems (Mac) 3 03-19-2014 12:46 AM
Can i use 4 ins/outs/ as hardware sends? SMonkey Pro Tools HDX & HD Native Systems (Mac) 13 09-26-2012 09:23 AM
issue with AUX sends for phones albee1952 General Discussion 3 04-13-2011 02:54 PM
Hardware Inserts and Sends joey.arbogast 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-30-2011 08:05 AM
