Old 09-22-2011, 11:33 PM
the19thbear the19thbear is offline
Default Akai MPK mini problems.
Hi. I just got a small Akai mpk mini keyboard.
as for now, i dont care about the controller parts/pads - i just want to use it as a normal keyboard controller to play vacuum etc.
The problem is that i cant select the mpk mini as input anywhere. - i plug the keyboard in via USB, fire up pro tools, go to "midi devices" or whatever it is called:) - a drop down menu in pro tools, and the mpk mini is not listed. I have restarted my computer, installled the mpk software, but it doesnt help.
I simply cant select the mpk mini as my input anywhere?!?
- it is recognised by windows, and i can use it in reaper
Any hints?
thanks!:)
Im on windows 7 32bit, pro tools 9 native
Old 03-06-2012, 01:41 PM
Brian in Charlotte Brian in Charlotte is offline
Default Re: Akai MPK mini problems.
I can't find out how to configure mine either. I've used a keyboard that had a midi connector before, with no issues, but this USB thing has be baffled. I've tried contacting AKAI, but they never replied. I'm sorry I bought the thing....gathering dust!
Brian on the Florida Suncoast
TheVoiceofBrian.com
iMac 5K 4.0GHz i7 Quad-Core, 24Gigs RAM, Radeon M295X, 1TB SSD, ThunderBay 4 w/2TBSSD, ThunderDock, OS 10.12.1, ProTools 12.7 Avalon M5, Focusrite Clarett2Pre, Sennheiser 416, Michael Joly Engineering Rode NT1A U87'esqMod
Old 03-06-2012, 02:30 PM
the19thbear - JUST GOT IT TO WORK!!!!! Perhaps you've done this, but on my Mac, opened PT10, in the top bar I chose "Setup", then I went down to "Peripherals", then to "Machine Control", under the first window that says "Midi Machine Control (Master), I ticked ENABLE, then chose the MPK Mini. DONE
TheVoiceofBrian.com
Syncing the AKAI MINI MPK with Pro Tools 9 theorowe MIDI 1 10-25-2012 10:51 AM
any guides or primer on using Akai MPK mini with Pro Tools luism macOS 2 03-31-2012 06:51 PM
akai mpk mini Daniel Darbon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-13-2012 09:05 AM
akai mpk mini Mr. MIDI 0 10-07-2011 10:27 PM
Akai MPK mini Craigorywayne macOS 2 05-21-2011 07:24 PM
