Old 03-26-2011, 09:49 PM
georgelegeriii georgelegeriii is offline
Default Surround mix plug-in during opening of session file
Just completed an upgrade of PT9 HD from PT 8 HD. I did a clean install removing all Digi components (other than the plug-ins). things seemed to go smoothly.
Upon opening the first session, I discovered that I wasn't able to open a session that I had no problems with before. When PT was scanning the plug-ins used by the session, I kept noticing a strange plug-in I hadn't ever seen before, that appeared to be a surround component. If the session was being opened as a surround session,than that would explain the reasons why we no longer had the DSP required.
I have had to revert back to PT 8HD since, due to this issue as well as others (the new I/O settings not appearing to work properly, loosing busses, misc strange things regarding I/O).
Has anyone seen this type of an issue and been able to resolve it?
George
system:
Model Name: Mac Pro
Model Identifier: MacPro2,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 3 GHz
Ram: 16 GB
Mac OS 10.6.6
Protools HD 9.02 on a HD 3 Accel system w 6 192 interfaces.
www.utopiaparkwaymusic.com
Opening or transferring a wav file into a new Pro Tools Session Lou21 macOS 6 02-19-2013 02:58 PM
Problem Opening Session - PT Says Plug-in Not Installed Alan Brownstein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-25-2008 03:44 PM
Opening a PT7 session file in 6.9.... OneRoomStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-26-2006 11:41 AM
Help!! When opening session, window pops up saying "file not on a valid drive?" ?? Rockman-Songwriter Pro Tools TDM Systems (Mac) 9 04-25-2003 05:03 PM
Opening Session w/missing audio file Cliff Adams General Discussion 3 09-24-2001 05:10 AM
