Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 01-02-2011, 04:24 PM
sfwdslashx sfwdslashx is offline
Default After recording vocals, there is no sound during playback. Why?
I just bought Pro Tools SE with the M-Audio Producer USB Microphone the other week, and I've reinstalled it like three times now. I keep getting "DAE error -9060 was encountered," among other various error numbers as well.
My main problem is that when I begin recording vocals, I can hear myself just fine, so I know that the microphone is working. But about 3 out of the 4 times I do record, when I try to play it back, there is no sound. Can anyone help me?
I'm running Windows 7 64-bit with a 620GB hard drive and 4GB of memory, along with an Intel Core i5 processor on a brand new Samsung QX410 Notebook.
Old 01-05-2011, 11:02 AM
Ben H Ben H is offline
Default Re: After recording vocals, there is no sound during playback. Why?
Hi sfwdslashx,
Do you see a waveform recorded on your vocal track?
Old 01-12-2011, 05:51 AM
Avid Product Design Avid Product Design is offline
Selecting "Mixing or Producing" in Preferences > Audio may help with this issue.
Product Designer
Old 01-02-2012, 03:02 PM
bigjohnjps bigjohnjps is offline
I have the exact same issue.
i can record several times. Waveform shows up. No audio on playback.
Will have to return if I can't fix.
Old 01-17-2012, 04:14 PM
Kasactress Kasactress is offline
I am also having this problem with Pro Tools SE. I have tried doing preferences>mixing/producing and it doesn't seem to change anything. Anyone come up with a solution to this?
Old 01-22-2012, 10:10 AM
CPG CPG is offline
I don't know if this is relevant, however all the problems I encountered (ie errors, no playback, distorted playback, pops and cracks) were solved by getting an external hard drive....
Also, PTSE seems to work better with audio (mic'd instruments) rather than line in). Just an observation.
I recorded a 5 minute song with my band on my system, with 16 audio tracks and effects on most... not one problem. And I only use a dell inspiron 1545 3GB RAM etc...
It can be done!
Old 02-08-2012, 04:36 PM
Pingafuego Pingafuego is offline
CPG, what kind of external drive are you using? USB or FireWire?
Thanks
Old 10-25-2012, 02:15 AM
monkeysticker monkeysticker is offline
I resolved the crackling issue using revo uninstaller and unistalling Pro Tools SE completley. Revo will also search the registry and delete windows registry keys you have to select the option.
I found that an anti virus or anything thast uses computer resources is better not to have running, maybe even during installation.
I think the issue is the USB Producer mic drivers, one can also go to the hiden icons in the task bar and double click the m-audio icon it will open the driver mixer panel. There you can play around with the driver pre amp volume maybe just adjusting this might also resolve the issue. You can also adjust the pre amp imput level through the mixer panel. But the best thing is a clean reinstall.
Hope it helps...
Monkeysticker
Old 10-25-2012, 08:21 PM
Dcader10 Dcader10 is offline
Hello All,
You may have done this already but if not, did you arm it to record for that track? You also have to click on Record above and on play before starting to record.
Hope this helps,
Dcader10
Recording vocals - sound dry in song. Help with EQ, etc Mattitude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-22-2009 11:02 AM
Robot sound when recording vocals THE KAMEN BIZ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-14-2008 05:04 AM
PlayBack Delay In Vocals When Recording!!Help!!! Las Philosophy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-03-2007 07:36 AM
No sound when playback after recording chillax69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-12-2006 01:32 PM
hear vocals during playback w/o actually recording them? Esteban 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 03-08-2002 01:59 AM
