Old 08-21-2006, 12:17 PM
TCLguy1 TCLguy1 is offline
Default Is 10.4.7 supported ?
I am currently running 10.4.6, is the update to 10.4.7 Digi approved ?
Thanks
Best,
TCLguy
_________________________________________
12-Core Xeon 3.33, Antelope Audio Goliath, Logic, Live, PT12HD
Dual 2.7 G5, ProTools HD3, 2*192's, SSL Delta Link
iMac 3.0 , Abelton live
MacBook Pro, Logic X for Video
Old 08-21-2006, 12:37 PM
Dopamine Dopamine is offline
Default Re: Is 10.4.7 supported ?
I would really lovr to get an answer for Digi. I just installed Tiger for a client and need to know if I can run software update. For some reason after I installed 10.4.0 it will not let me install the 10.4.6 updater.
On hold with Digi now....
http://www.phuturetrax.com
Old 08-21-2006, 12:48 PM
crizdee's Avatar
crizdee crizdee is offline
Digidesign PT 7.2 mac support page....
General Compatibility:
Pro Tools HD 7.0/7.1, Pro Tools LE 7.0/7.1, and Pro Tools M-Powered 7.0/7.1 are officially supported on Mac OS X 10.4.2, 10.4.3, 10.4.4, 10.4.5, 10.4.6, or 10.4.7 for PowerPC-based Macs
Pro Tools HD 7.2 is officially supported on Mac OS X 10.4.6 or 10.4.7 for PowerPC-based Macs
Pro Tools LE 7.1.1 and Pro Tools M-Powered 7.1.1 for Intel-based Macs are officially supported on Mac OS X 10.4.6 or 10.4.7 for Intel-based Macs
Pro Tools Academic 7.1.1 and Pro Tools M-Powered Academic 7.1.1 are officially supported on Mac OS X 10.4.6 for PowerPC-based Macs
About Mac OS X 10.4.7
August 16, 2006: Pro Tools HD 7.2, Pro Tools LE 7.1, and Pro Tools LE 7.1.1 have been officially qualified with Mac OS X 10.4.7
Media Station|PT 1.8.2 is NOT compatible with Mac OS X 10.4.7
Testing is in progress with Pro Tools M-Audio systems with Mac OS X 10.4.7
Pro Tools|HD & Pro Tools|HD Accel Systems (PowerPC Only)
Pro Tools HD 7.2 is officially supported on Mac OS X 10.4.6 and 10.4.7 (Tiger)
Pro Tools HD 7.1 is officially supported on Mac OS X 10.4.3, 10.4.4, 10.4.5, and 10.4.6
Pro Tools HD 7.0 is officially supported on Mac OS X 10.4.2, 10.4.3, 10.4.4, 10.4.5, and 10.4.6
Pro Tools HD 7 will not run on Mac OS X 10.3.9 (Panther) and earlier
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 08-21-2006, 05:23 PM
davip davip is offline
Crizdee, what page are you looking at? On the Protools 7 Power Mac G5 PCIe page it says:
P{ro Tools HD 7.2 is officially supported on Mac OS X 10.4.6 and 10.4.7 (Tiger)
It used to continue by saying that OS 10.4.7 was being tested with PT 7.1, but that line has been removed.
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 08-21-2006, 06:29 PM
Thanks, yeah it looks like 7.1 and G5 PCI is not supporting 10.4.7....sounds a bit like, we will be left behind from now on. It's okay, I am used to it. Workaround: Shelf out 10G's and upgrade to PCIe...
T
Best,
TCLguy
Old 08-21-2006, 06:40 PM
No, it's not a question of PCI vs. PCIe. The page I quoted above was the G5 PCI page. It's a question of PT 7.1 vs PT 7.2.
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 08-21-2006, 07:34 PM
Ray Lyon Ray Lyon is offline
"Pro Tools HD 7.0/7.1, Pro Tools LE 7.0/7.1, and Pro Tools M-Powered 7.0/7.1 are officially supported on Mac OS X 10.4.2, 10.4.3, 10.4.4, 10.4.5, 10.4.6, or 10.4.7 for PowerPC-based Macs"
vs
"Pro Tools HD 7.1 is officially supported on Mac OS X 10.4.3, 10.4.4, 10.4.5, and 10.4.6"
Huh? Is 10.4.7 compatible with PT 7.1 or not?
Ray Lyon
www.raylyon.com
• Mac Pro 5,1 flashed 2009 model 4,1
• 12-core 2.93ghz "Westmere", 64 GB RAM
• OS 10.13.6 High Sierra, PT 2019.5
• One plug-in too many, but I really like FabFilter Pro-Q 3
• Avid HDX, Revive Audio modded Avid 192 I/O
• Avid MIDI I/O, Avid Command|8
• 256GB SSD, (2) 2TB ext. drive
• NVIDIA GeForce GTX 960 2048 MB
• Samsung 34" SE790C display (3440x1440), Acer 23" A231H Display
Old 08-21-2006, 07:48 PM
Avid's Avatar
Avid Avid is offline
Administrator
In addition to that mistake in the first line you quoted, that whole redundant "general compatibility" section on the Mac OS X page was confusing.
It should be clearer now on the Mac OS X 10.4 page linked from the compatibility section of all Tiger-compatible Pro Tools systesms:
Mac OS X 10.4 Requirements with Pro Tools 6 & 7
This information is correct:
  • Pro Tools HD 7.2 is officially supported on Mac OS X 10.4.6 and 10.4.7 (Tiger)
  • Pro Tools HD 7.1 is officially supported on Mac OS X 10.4.3, 10.4.4, 10.4.5, and 10.4.6
  • Pro Tools HD 7.0 is officially supported on Mac OS X 10.4.2, 10.4.3, 10.4.4, 10.4.5, and 10.4.6
  • Pro Tools HD 7 will not run on Mac OS X 10.3.9 (Panther) and earlier
  • Pro Tools HD 7.1, 7.0, and 6.9.2 not tested with 10.4.7
As is this information on the same page:
  • August 16, 2006: Pro Tools HD 7.2, Pro Tools LE 7.1, and Pro Tools LE 7.1.1 have been officially qualified with Mac OS X 10.4.7
  • Media Station|PT 1.8.2 is NOT compatible with Mac OS X 10.4.7
  • Testing is in progress with Pro Tools M-Audio systems with Mac OS X 10.4.7
Apologies for the confusing typo on the previous revision of that page.
10.4.7 was tested and qualified with all currently shipping versions of Pro Tools LE (7.1 and 7.1.1) and Pro Tools HD 7.2.
That doesn't mean that earlier versions such as PTHD 7.0 or 7.1 are incompatible, but since they were not tested, they are not officially supported.
Administrator
How many CPU supported Raggi Pro Tools 10 1 12-01-2011 11:48 AM
10.3.3 - when will it be supported? charles maynes Pro Tools TDM Systems (Mac) 3 05-05-2004 12:36 PM
SSC not supported in PT 6 with OSX ??? WHAT? Ray Fabi Pro Tools TDM Systems (Mac) 188 01-16-2003 11:19 PM
2nd IDE HDD not supported BMP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-27-2000 06:51 AM
why is os 9.0 still not supported? slinky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-21-1999 11:59 PM
