Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 09-26-2019, 02:06 PM
skilletaudio skilletaudio is offline
Default Full Channel Strip for Focus Fader
Is there a way to designate a different channel as the focus fader? I loved on the System 5 that I had full control of the focus fader. The same thing on the D-Control. This would be more like what you did on the D-Command and made a quasi focus fader.
Old 09-26-2019, 02:08 PM
creativecontrol's Avatar
Default Re: Full Channel Strip for Focus Fader
No, the Attention Fader is assigned or de-assigned to the Automation Module.
Jeff
Jeff Komar
Old 09-30-2019, 09:46 AM
Okay thanks Jeff, hopeful that could be added as an option I'd love to be able to use a full channel strip for a focus fader if possible.
Old 10-06-2019, 03:33 PM
kosmokrator kosmokrator is offline
the workaround I use is to assign faders on the right side from 2 up to the second spill zone and have fader 1 always bank to the attentioned track.
Old 10-16-2019, 03:51 PM
That's a great idea, if I understand you correct
  1. The right spill zone is 2 - whatever
  2. Tracks local option "Auto-Bank to Attentioned Track" is enabled.
  3. Settings:User:Banking Justifcation Mode:Right of Master Module
  4. Settings:User:Automatic Spill of Attentioned VCA:Spill Zone Right
are your settings. The reason for number 4 is so I can see my VCA master right next to the spills if I attention a VCA. I can only attention from the Tracks page and not from the attention button on a fader (which in most cases would be what I would need).
With our configuration, I would set it this way if it helps anyone based on your great idea! It would be nice if the attention button also could work with this (perhaps it can and I am missing a setting). Center section faders have to be faked out as to the far right of the console after the faders on the far right side and set as a right spill zone (still working out best preferences as workflows develop).
1) The left spill zone is 1 - 15
2) Tracks local option "Auto-Bank to Attentioned Track" is enabled.
3) Settings:User:Banking Justifcation Mode:Left of Master Module
4) Settings:User:Automatic Spill of Attentioned VCA:Spill Zone Left
5) Settings:User:Spill Left (and Spill Right) Justifacation Modes: (left side) Right.
Semes like a pretty nice solution, I'll have to play with that for a few sessions.
Can I lock a fader similar to ICON Focus Channel? macaholic Artist Series 1 12-15-2010 01:13 AM
Focus strip erratic volume automation rbeggs ICON & C|24 3 01-15-2010 12:58 PM
question about focus channel fader tomcat ICON & C|24 2 07-09-2006 11:19 PM
Channel Strip on Stereo Master Fader stevemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-15-2002 09:25 PM
Channel Strip and Master Fader fifty8th1 Tips & Tricks 5 06-07-2001 03:56 PM
