Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 05-22-2018, 06:50 PM
MarkoPete MarkoPete is offline
Default Cannot use my USB Mic and Playback Sound at the Same Time
I am using ASI4All.
I Cant enable Realtek High Definition Audio and my Sampson USB mic at the same time using ASI4All.
If I want to record I need to disable Realtek High Definition Audio then enable again for normal playback.
I have some screenshots showing my settings attached.
I am new to Protools and audio recording, I have spent hours to get this far :)
Thanks for any help.
Old 05-22-2018, 07:52 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Cannot use my USB Mic and Playback Sound at the Same Time
I'm not sure why you are using ASIO4all. ProTools first can output through Windows audio just select WASAPI as audio engine in pro tools. I've never used a usb mic so I cant offer too much help there but most usb interfaces(your mic in this case)have drivers you can download so that they will be recognized by Pro Tools. Check the website for your Mic.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 05-22-2018, 08:29 PM
I installed it because Protools didn't see my USB mic ( Sampson Meteor Mic Studio) After installing and setting up ASI4All Protools now see's it.
There are divers for the Mic that I can find, it users Microsoft driver as installed by windows 10.
Old 05-23-2018, 02:28 PM
Problem solved, there can only be one input and output selected in ASI4All.
Not multiple as I had, simple and makes sense when you think about it :)
Clip Gain won’t update in real time during playback on Elastic Time tracks yanos macOS 0 06-03-2012 03:48 PM
Popping sound every time audio playback is stopped Stay Where I Can macOS 11 12-12-2011 09:09 AM
Wierd sound during playback and recordings are off time. alvg1199 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-11-2011 04:05 PM
Mbox2 with no sound at all (from time to time) Cyri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-06-2011 02:07 AM
mbox sound playback degredading over time... romerom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-27-2004 08:45 AM
