Old 03-12-2019, 05:42 PM
gdgross's Avatar
gdgross gdgross is offline
Default Looping a recording
Interesting idea i had.
I do some guitar looping with pedals for live performances, and I'd like to try something like that for a live video with my band, while recording to a full PT session with a click/etc.
Would it be possible to do this?
For Example: after the count off, protools records 2 bars of some instrument playing something, then continually repeats those two bars back for the duration of the recording while recording normally on the other tracks. I don't want to record in loop mode, as we'd be recording a full song, and unwinding loop recording and piecing back together would just be a nightmare.
I'd like the live loop to be in sync with the click for the duration of the song. Any way to do this? (I might just be creaming here...)
I don't believe any of my external looper pedals will sync their loops to midi clock or anything like that unfortunately.
Thanks all!
Geoff
www.merlotembargo.com
Old 03-13-2019, 05:51 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Looping a recording
Why not just create your loop and hit copy or duplicate until its as long(or longer)as you think you will need to be able to jam to?
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 03-13-2019, 08:02 AM
junkgear's Avatar
junkgear junkgear is offline
You can use the Clip->Loop feature.
Looped clips repeat the source clip as many times as specified in the Clip Looping dialog.
Will
System Details
Old 03-13-2019, 08:53 AM
john1192 john1192 is offline
Thanks all!
i do not think PT can do this without stopping and starting why not use a looper pedal .. and record that to pro tools LIVE ..
the thing that might work is using Ableton LIVE .. setup the looping in there / locked to pro tools ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 03-13-2019, 10:01 AM
amagras amagras is offline
You have to research how Louis Cole does it but I think he uses Ableton
https://youtu.be/IxEIQQkhyeI
Ps. Watch the whole vid, it's awesome
Edit. John said it ^^^
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 03-13-2019, 10:50 AM
JCBigler's Avatar
JCBigler JCBigler is offline
Protools is a recording software, not a sequencer. To do what you want your u need a different piece of software, like Ableton.
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 03-14-2019, 01:24 PM
gdgross's Avatar
Thanks guys -
An external looper pedal is my best option so far, and the one I probably will go with, unless looking into Ableton looks super attractive for some reason.
The main thing I'd need is the loop playback, but I'd also like to have a click running. Seems like an impossibility in PT.
Geoff
Old 03-14-2019, 05:29 PM
gdgross's Avatar
For anyone following along at home, I figured out how to do this, although not 100% in protools.
Just need a MIDI track and a looper pedal that accepts midi CCs to start and stop the looper. Mine does (fractal audio ax8 has this capability, although I'm looping a recorded percussion loop, not guitar, so I'll need to mic/preamp/adapter into the ax8).
Just need to set up a midi track in PT with the appropriate CCs to trigger my external pedal. Good enough for me, loop and click will be in sync for the entire recording time.
Geoff
Old 03-15-2019, 03:12 PM
the.engineer the.engineer is offline
Ah man...Louis Cole.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Recording while other tracks are looping? spaids 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-10-2007 05:33 AM
Recording MIDI - Looping krazylain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-27-2007 12:34 PM
MIDI Recording whilst looping. Sydes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-27-2007 04:36 AM
looping midi - recording audio mecanoiz Tips & Tricks 3 07-16-2004 02:53 AM
Looping and Recording? Need a little help! RE9 Pro Tools TDM Systems (Win) 7 03-18-2003 12:56 AM
