Old 09-28-2016, 03:52 AM
marsian marsian is offline
Default Alert! AAF Bug MC - PT
Hi guys,
I just explored a bug, that is confirmed by my dealer:
In new Mediacomposer versions (eg. 8.6.2), it is possible to use "i" and "p" formats in the same timeline (eg. 1080i and 1080p). This results in shifted audio (more than 2sec.) in clips, that are imported via AAF in Pro Tools. Not every audio is shifted, only a few pieces (the mixed ones).
Every PT version before 12.5.2 (12.5 not tested) shows this issue.
I find it rediculous, that AVID was silent on this.
Cheers
Maik
Old 09-28-2016, 08:59 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Alert! AAF Bug MC - PT
Just to clear things up, is it fixed in 12.5.2 ?
To add some AAF issues, I've found there can be a difference in dragging an AAF into the timeline and using the 'import session data' from the menu (the latter is working properly). The regions are in place but referencing the wrong audio (or wrong part of the audio). I haven't delved too deep into the issue though...
Old 09-28-2016, 02:44 PM
...yes, it's fixed in 12.5.2
Old 10-03-2016, 07:25 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Originally Posted by marsian View Post
Hi guys,
Can you confirm this to be the only cause for this bug?
We have run into similar issues and all the production sound was shifted, only the Music tracks and recorded guide Vo clips were in sync.
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 10-04-2016, 05:35 AM
Hi Vedat,
no, I can't confirm, that this is the only cause. It's what my dealer told me and what I experienced. But I made no tests with different MC Material.
Cheers
Maik
Old 10-04-2016, 11:58 PM
Vedat's Avatar
Quiet Art Ltd.
OK thanks.
I am just digging as much information as I can to be able to feed back to the editors for a smoother workflow.
Vedat
QuietArt.co.nz
Catchin' SYNC app
Old 10-05-2016, 01:30 AM
garret garret is offline
We've had this issue but opening the aaf in pt10 works correctly and then we just save the session open in pt12. Good to hear potential causes of this issue. Thanks.
IMDB
Old 10-05-2016, 01:50 AM
Vedat's Avatar
Quiet Art Ltd.
For us anything below 12.5 is messed up.
Vedat
QuietArt.co.nz
Catchin' SYNC app
Old 12-20-2016, 08:05 AM
Default New Alert! AAF Bug MC 8 -> PT 12.5.2
Hey guys,
the former mentioned bug was fixed in HD 12.5.2. But I discovered a new bug in PT 12.5.2 and 12.6.1:
When there is interlaced 30FPS material mixed with 25p or 50i in the timeline, then there is an offset in the audio AAF out of Mediacomposer 8.6. It is only visible when importing in Pro Tools. When imported in MC it is as it should be.
This bug ist NOT in Pro Tools 11.3.2!
And after a few hard crashes and video sync problems in HD 12.5.2, I switched back to PT 11.3.2 and Blackmagic driver 10.4.3. So far it feels way more stable.
I'm really disappointed of Avid. It seems that the newer the version you use, the more bugs are in there.
If version 12.7 won't fix that bugs, we won't upgrade support for our three systems next year.
It's a shame.
Cheers
Maik
Old 03-15-2017, 12:22 AM
_underscoreaudio _underscoreaudio is offline
I am still getting this issue with Pro Tools |HD 12.7.1, but only when doing SRC on import.
ie, 25fps project converting to 24fps using 46080Hz option gives me the correct edits, referencing the incorrect section of audio.
Any concrete ideas on how to get around this, other than importing the AAF at 25fps and X-Form ing everything?
Edit: to update - OMF's seem to import just fine*, so this works for short projects. Encapsulated AAF's definitely do not work when doing SRC conversion
*By fine, the OMF we ended up working with did the SRC properly, and the edit points and corresponding audio were in the correct places, but the whole thing was down the timeline by 10sec and 10 frames. I don't know if that's the result of a frantic editor running back and forth between his machine and mine, or if it's another bug.
Last edited by _underscoreaudio; 03-15-2017 at 02:50 AM. Reason: additional information
HTML code is On
Long alert -jam Red Raven Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-11-2014 05:34 PM
New Product Alert... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-27-2009 03:18 PM
