Old 09-04-2016, 11:46 PM
amac733 amac733 is offline
Default Dynamics for gun shots and other loud noises to keep them from peaking
Hello everyone!
I'm having a bit of trouble trying to keep gun shots under the -7db limit I have to hit according to the delivery specs for the project I'm currently on.
It's a acton movie, so there's quite a few gun shots and I can't seem to have them not peak. And when I use a limiter, it just crushes the sound and makes it sound like crap.
Any tips or tricks would be greatly appreciated. Thanks!
Old 09-05-2016, 07:57 AM
nst7 nst7 is offline
Default Re: Dynamics for gun shots and other loud noises to keep them from peaking
You'll get a quicker and more accurate answer for this type of question by posting it in the "Post and Surround" section of the forum.
Old 09-05-2016, 11:51 AM
True^^^ and you can also use Clip Gain and a good metering plugin to adjust to target level
Old 09-05-2016, 01:19 PM
Mark Ziebarth Mark Ziebarth is offline
Clip Gain is your friend...
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2019, Euphonix MC Control
Old 09-06-2016, 12:57 PM
Sndnerd Sndnerd is offline
If you're tied to a -7 spec you're going to have to lean into that limiter a bit. Make sure you use a good one.
Old 09-07-2016, 07:56 AM
Also try using some kind of attenuator between the mic and the interface. Or use the one on the mic if it has one. What mic are you using? How close are you mic'ing the gun? Try backing off a bit and use a muffler on the front end of the mic.
The other alternative is to use something from a sound library.
Jack
QAPLA!
Old 09-07-2016, 10:22 AM
garret garret is offline
If you are tied to that peak level and it sounds crap when you limit, then I would suggest raising your monitoring level when you are mixing so you don't have to lean on the limiter as much. That should solve the problem. You will have the loudness you require while still achieving the peak levels you need to hit. You may need to globally readjust overall levels to the new monitoring level at first but it will solve your issue.
IMDB
Old 09-07-2016, 10:31 AM
I'm actually doing the post sound mix and edit. But thanks!
Old 09-07-2016, 10:34 AM
I was under the impression that once I calibrate my monitors, I should always edit and mix at that level. I've read of people lowering the overall volume with the trim plug-in on the master channel. But I may give your idea a go! Thanks!
Old 09-07-2016, 01:18 PM
That's what I mean about rebalancing once you choose a new Monitoring level that the gunshots sound good at. Then you don't change that level from then on. My feeling is you have chosen too low a monitoring level to begin with. What level are you mixing at?
IMDB
HTML code is On
Old Pro Tools De esser causing loud noises and feedback looo joe_04_04 macOS 2 06-18-2014 02:04 PM
Expander Gate/Dynamics III vs Drawmer Dynamics DaveSB Pro Tools TDM Systems (Mac) 14 01-31-2007 06:26 AM
Loud Noises rodrigal1 Pro Tools TDM Systems (Mac) 3 07-18-2006 05:28 PM
Loud noises when adding plugs and duping tracks Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-29-2005 07:43 PM
Screen Shots Kalara 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-24-2004 10:21 PM
