PT LE: crash after pushing stop
From a while I encounter a crash problem with my PT LE, but it's hard to locate the reason why it happens, because it NOT ALWAYS HAPPENS!
Here is the scenario: I launch a PT doc and begin to play the song hitting the spacebar; when I hit again the spacebar so that stopping the song....aargh: PT crashes, and this error message appears: "System error ProTools LE error 10". So I have to reboot the system and when I relaunch PT this problem has gone: all is fine! Any idea? Thanks Fulvio
MUSICNET STUDIO Via Puini, 97 57128 Livorno ITALY |
Re: PT LE: crash after pushing stop
Hi neighbour !
More setup infos needed here (what MacOS, what PT V°, what Mac, what kind of drives...).
Some music?... http://tmweb.free.fr |
PowerMac 7500/UpgrG3/300/150
PT le 5.1.1 Digi001/DAE 5.1.1 LogicAudioPlatinum 4.7.3 SoundDiver 3.0.4 MAc Os 8.6 336 Meg RAM 1stHDAudio: Quantum Atlas 2Gb 2ndHDAudio: Seagate ST39204LW 9Gb Ultra3 SCSI bus: Atto PCI UL3D Sony DMX-R100/ADAT card DMBK-R106
The 7500 only has a single PCI bus, which all three slots share. Running a scsi accelerator and a 001 PCI card together on the same bus is bound to overload it.
You would actually be better off removing the scsi card and using your audio drives on the built in internal and external scsi connections. I don't know how fast the internal scsi bus is on a 7500, or if it is separate from the external scsi, but on the 8600 and 9600 models, the internal scsi is fast scsi (10 mbs) and the external scsi connection is separate and runs at 5 mbs.
Administrator Avid Pro Audio Community |
OK, I see. Anyway many times the problem doesn't occur, and surely it doesn't occur if I launch PT as the first application after booting my Mac.
Thank you for your response Fulvio
New I Mac with FW 800 to M Box2 pro with FW 400 its keep stop and crash.. | DJ Romy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-17-2010 05:29 AM |
Crash after hitting stop | nukeit11 | Pro Tools TDM Systems (Mac) | 4 | 03-30-2006 05:55 AM |
Blue Screen Crash Stop Code 0x00000019 | spiess21 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-13-2006 10:57 PM |
push stop and crash! | the purple void | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-21-2002 10:00 AM |
Pushing the 001 to the max. | keysmia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-02-2000 06:56 PM |
