Old 12-05-2019, 04:51 AM
m4tune m4tune is offline
Default Control App: Pressing "config" blocks most functions
When pressing "config" in Channel View while a plug-in is showing the parameters on the ipad a lot of buttons become non responsive, i.e. selekting other channels, other inserts, etc.
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6
http://www.4tune.at
Old 12-06-2019, 08:26 AM
EddieJones's Avatar
Default Re: Control App: Pressing "config" blocks most functions
Correct...you have entered config mode. Come back out to carry on as normal
Old 12-09-2019, 02:38 PM
by clicking config again?
This doesn't work on my side…
http://www.4tune.at
Old 12-09-2019, 02:47 PM
EddieJones's Avatar
Are you saying the Config button orange light stays on and wont turn off ?
Old 12-09-2019, 06:06 PM
abc1mce2's Avatar
abc1mce2 abc1mce2 is offline
Same here Eddie. Let's say on an audio track I select insert then Config. Next, I select insert A, DSP, Avid, 7 Band EQ. All is good and I can press Config and it (the indicator light) turns off and everything is fine. I switch from Insert to Input, EQ, etc. If I go back to insert A the EQ opens and the parameters spill out as usual. If I press Config, knob (slot) A say <fctorydefault> (for factory default presets) press <fctorydefault> then Bass, then Bass Monster. Now EQ7 shows the EQ curve and preset for Bass Monster. I press the Config button and the EQ parameters spill back out on the App and Dock, but only now most buttons and function on the App and Dock don't work. Pro Tools itself still functions as normal unless I try to close the session which works fine but I can only force quit PT cause it has crashed. When this happens the workaround is to restart Eucon before I quit the session and or not to use Config to select presets. This is the one crash I have recreated 7 times in a row.
Update: After selecting a preset if I press Insert, Input, etc and not press Config, everything works as expected and Eucon doesn't crash. This is the best workaround but Eucon shouldn't crash just because of pressing Config after selecting a Plugin's preset.
What is more relaxing than Music?
Pro Tools Carbon for macOS 12.7.4
My HDX for Windows11.
Gigabyte Z490 Vision D - BIOS F21b
Intel Core I9 10850K Windows11 / macOS 12.7.4 Hackintosh / 32GB of Rams
Avid Carbon/HDX 2024.3 Ultimate - 8x8x8 HD I/O - PT Dock - PT Control - Artist Mix (1)
Universal Audio Apollo Twin|X - UAD2 Pci-E and Satellite USB Octo v.11.0.1 - SOLO 610 - Twin-finity
Bricasti M7 (2)
Lexicon PCM96
Neumann KH805 - KH310
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Old 12-10-2019, 09:41 AM
EddieJones's Avatar
Thanks for the great repro steps! this helped our testers reproduce it quickly and its already assigned to a software engineer to fix. (for 19.12.1)
Old 12-19-2019, 08:29 PM
abc1mce2's Avatar
Great job once again Eddie. This issue is now fixed in Eucon 19.12.1
Bricasti M7 (2)
Lexicon PCM96
Yamaha NS-10M
Avantone Mixcubes
Grace Design M905
Etc, etc, etc.
Double Pressing "Dyn" and "EQ" on Process Module skilletaudio Avid S4/S6 4 02-28-2021 12:47 PM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 05:46 AM
"Select by Touch" blocks automation writing Tim R. Avid S1, S3, Dock and Control App 4 07-10-2015 10:40 AM
"PLAY" functions stops randomly Kenmillerjr macOS 8 11-07-2011 02:22 AM
DSP memory blocks in "System usage" -window boijermaj Pro Tools TDM Systems (Mac) 9 10-23-2009 01:49 PM
