Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-09-2021, 01:04 PM
Jazzbass56 Jazzbass56 is offline
Default Protools Ultimate pre record
I'd. like to know how to set a pre-record time in pro tools, for example, I'm punching Measure 3 beat 1, but I want to have PT record say 2 beats before the punch iN point, so I don't lose pickup notes, or I need a little head to do a better x fade
I hope I made this clear, In Nuendo, I can set the amount of prerecording, before the actual punch point, I'd like to do the same in Pro Tools
Cheers
Intel Intel Core i7-5930K 3.5 GHz Processor
ASUS X99-PRO/USB 3.1 Motherboard,64 GB crucial DDR4 ram
Thunderbolt EX 2
Windows 10 Pro
2013 MacBook Pro Retina i7 Quad-core, 16gb ram.
Mac OSX 10.11.6
Mac Pro (Late 2013)
2.7 GHz 12-Core Intel Xeon E5
Memory 128 GB 1866 MHZ DDR3
Graphics AMD FirePro D700 6144 MB
PT Ultimate 2022.4.0 on Mac
PT Ultimate 2020.12 on Windows
Logic Pro X 10.6
Nuendo 12.0
1_Antelope Audio_Orion Synergy Core Studio
Old 02-09-2021, 01:32 PM
Rich Breen Rich Breen is online now
Default Re: Protools Ultimate pre record
If you're in QuickPunch mode then Pro Tools is in "record" all the time regardless of where you actually make the punch - you can 'peel back' the newly recorded region to where you went into play and/or where you stopped regardless of where you actually punched in and out.
If you want to do auto-punches then pre/post roll times are set in the transport bar at the top of the edit screen or by dragging the pre/post roll markers in the timeline ruler or by option clicking anywhere on any track prior to or post the punch point.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-09-2021, 01:33 PM
m4tune m4tune is offline
When you activate "Quick Punch" in the options menu Pro Tools record from wherever you start playback. After the recording pass you can trim the audio clip back to where playback has started.
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.15.7 (Catalina/Dosdude), 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 1x Digi Pre, 1x Red8Pre 2x Avid S1. Artist Transport, PT2021.6
http://www.4tune.at
Old 02-09-2021, 01:36 PM
DetroitT's Avatar
DetroitT DetroitT is offline
If in Quick Punch, Pro Tools is always recording.
So if you punch late you can just pull out the clip to find missed recording.
Old 02-09-2021, 02:15 PM
Hey thanks! to all the great responses and thank you I figure there had to be away... I was reading manual but somehow I did not see that mentioned or maybe I just was not paying close attention...
Thunderbolt EX 2
Windows 10 Pro
Mac OSX 10.11.6
Mac Pro (Late 2013)
Logic Pro X 10.6
Nuendo 12.0
Old 02-10-2021, 07:12 AM
I'm not sure if this is still the case (I would need to test it), but even in QuickPunch mode, Pro Tools doesn't background record when in PreRoll, only during "actual" playback. So setting the cursor at the punch point and setting PreRoll to the amount of preroll you want won't do what you're looking for, even in QuickPunch. You will need to place the cursor at the preroll point, start playback without preroll, then punch at the punch point, to be able to trim your punch point back.
Scott Gatteño
Old 02-11-2021, 06:55 AM
Originally Posted by originalscottyg View Post
I'm not sure if this is still the case (I would need to test it), but even in QuickPunch mode, Pro Tools doesn't background record when in PreRoll, only during "actual" playback.....
I don't think this is correct. In QuickPunch Pro Tools definitely *is* recording as soon as you go into play regardless of pre/post roll settings, and (with the possible exception of a buggy release somewhere along the way) has done so ever since Quickpunch became a thing.
Old 02-11-2021, 07:21 AM
You are absolutely correct. I just tested it, and in QuickPunch, Pro Tools definitely records during the preroll phase. This doesn't work if not in QuickPunch. I am fairly certain that there was a version, or series of versions, where this didn't work. But since I've been using Pro Tools since the free give away of version 3, I can't recall which version it might have been.
Thanks for calling this out, Rich, and getting me to go test and verify that it actually works!
Scott Gatteño
-1103 protools ultimate stanonbass Pro Tools 2020 6 10-18-2020 02:10 PM
Revibe 5.1 protools ultimate marmouche AAX Plug-ins 8 07-26-2019 05:37 AM
Pro tools 2018 ultimate and separate record drive ericsvizeny Pro Tools 2018 2 05-06-2019 08:36 PM
windows 10 protools ultimate bug stanonbass Pro Tools 2018 1 05-07-2018 06:28 PM
