Unbalanced/Balanced??????
Quick question are inputs 1-4 balanced and unbalanced..Is it the same for 5-8 to?My keyboards are both unbalanced going into inputs 1-4 which the 003 rack specs say there balanced.Is there gonna be a problem with this setup?Some were i read that the inputs 1-4,5-8 can except unbalanced and balanced is this true Thanks
Re: Unbalanced/Balanced??????
Yes the inputs can accept both balanced and unbalanced connections - so if your keyboard only has unbalanced outputs then that's fine. But you should ideally be using the line inputs 5-8 to avoid going through the preamp.
I use to use 5-8 but just trying something different..If i do use 5-8 should i keep the switch in the back -10 for unbalanced
The switch is for level and doesn't really care if the incoming signal is balanced or not. Start at +4 and adjust the keyboard volume. If you can't get the meters up to the yellow, switch to the -10 setting.
OK thanks for that...Which inputs do you prefer 1-4,or 5-8
Balanced or Unbalanced? | Vlad Drac | Tips & Tricks | 7 | 04-17-2007 12:47 PM |
Balanced and Unbalanced | Fishman1 | General Discussion | 2 | 09-25-2005 11:27 AM |
Balanced / Unbalanced | pipesurfa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-26-2004 01:44 PM |
Balanced or Unbalanced | Ross H | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-12-2004 05:38 PM |
Balanced or unbalanced | stickstome2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-12-2002 09:43 AM |
