Old 07-04-2003, 04:35 AM
babzenuda babzenuda is offline
Default DAE not recognising Project II card
Hi there, I just acquired a used Project II card to run with Logic (only found out now that it doesn't run with Protools software... whazzupwithdat?), but I can't seem to get it to work with DAE/DSI. Digitest v.5 reports that the card is fine, and I can output audio through the card/interface from Peak via the Digi sound driver, but DAE doesn't seem to recognise the card. It returns an error whenever I try to route the audio through DAE in Peak or Logic (when DAE launches, it says "Could not initialise a DAE deck" or "Digidesign hardware not found"). Am I missing something here? Any suggestions would be greatly appreciated.
Specs:
Beige G3 desktop 233 mHz, 192mb RAM, 8 GB ext. SCSI HD
Mac OS 9.0
DAE/DSI 3.4.2
Logic Audio 4.7, Peak 2.5
882 I/O (16-bit) interface
By the way, is there a manual available for the Project II card? I'm sure most of my questions would be answered if I could rtfm...
Thanks,
Robert.
Old 07-09-2003, 03:46 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: DAE not recognising Project II card
Pro Tools does not support the Project II card because there is no engine for the card in DAE.
It's up the the 3rd party app to provide the audio engine.
You might try EMagic's support section for more info:
http://www.emagic.de/support/support/index.php?lang=EN
linkedin
HTML code is On
Project card and 882 problems... bedheadbob Digidesign Hardware & Software 1 11-25-2006 07:46 AM
D24 / Project II same card??? Angus202 Digidesign Hardware & Software 1 11-05-2004 04:50 PM
project ll card ejtrip General Discussion 3 05-27-2002 04:22 AM
NuBus PMac with g3 card/Project card difficulties dubh General Discussion 0 12-08-2000 02:34 PM
upgrade project II card g3 to g4 trompi General Discussion 0 10-13-2000 05:04 PM
