PT will not start with Eleven Rack [SOLVED]
The last few months of 2017 my studio would no longer start as I work with an iMac and Pro Tools was not ready for High Sierra yet (I upgraded too soon). Now PT is finally compatible with High Sierra I still get stuck, as during start up my Eleven Rack (the audio interface I use for PT) won’t work with High Sierra. The following pop-up error appears when launching PT:
Could not complete your request because Assertion in "/Volumes/Development/218077/ProTools/AAE/Source/AAX/CFicAAXWidget.cpp", line 822 This is linked to the 11R not being recognized. My iMac states: device not connected although it actually is. The 11R has firmware version 2.0.1, build 0.1.5.7. I also notice that the ER is activated in iLok manager, 'local iMac' has 0 activations. I found following: http://avid.force.com/pkb/articles/e...t-cpp-line-822 but Option 1 already baffles me…it refers to link: http://www.avid.com/drivers and there it states: Last Updated : December 22, 2017 Products Affected : Eleven_Rack. So: 1) should I upgrade High Sierra 10.13.2 to Pro Tools 12.8.3? And if so, how? I do not find 12.8.3 anywhere and it is not in my Avid account 2) If I then go to ‘USB device driver’ and click on 11R drivers, I see “supports macOS Sierra 10.12” from 2016. No further update. Any advice what I should do now? Thanks paul |
Re: PT will not start with Eleven Rack
sorry, forget question 1, I already upgraded PT to 12.8.3
I think you need to get your 11R to show up in MacOS before you do anything else. I would install the latest driver on your system and make sure that when you open the 11R preferences window, it shows connected. Once you get to that point, then try holding down the N key while PT starts, which will force a hardware refresh and allow you to choose the audio device in the playback engine.
thanks for your help, finally works again!
nothing but trouble with Eleven Rack [SOLVED] | Kevin 62 | Eleven Rack | 5 | 12-01-2015 08:30 AM |
Possible Problem with Eleven Rack Mic Preamp [SOLVED] | keystation | Eleven Rack | 5 | 03-17-2015 08:19 AM |
Eleven Rack Won't Start Up | jazzrockblues7 | Eleven Rack | 1 | 01-13-2012 01:43 AM |
[SOLVED] Eleven Rack Noise Gate acting buggy | durak28 | Eleven Rack | 1 | 05-24-2011 02:36 AM |
SOLVED - Problem with the distorted sounds of the eleven rack! | Koffax | Eleven Rack | 3 | 05-02-2011 10:30 AM |
