6 second delay before recording begins
Hi. When I press record in pro tools 12.8 there is about a 6 second delay before the recording begins and a delay after the recording stops before the waveform appears. It doesn't seem to be related to the pre-roll because that was deactivated in the transport window.
Actually another frustrating thing is the pre-roll function does not work! PC, p6T motherboard. intel Core(TM) i7 CPU 920 @ 2.67GHz 2.67GHz windows 7 ultimate service pack 1, 64 bit,10Gigs RAM, Focusrite scarlett 18i20, Pro Tools 12.8 Last edited by johntee; 07-05-2017 at 11:24 AM. Reason: info about my system added |
Re: 6 second delay before recording begins
not a PC guy so can't help there .. could use a bit more info as far as the Pre-Roll thing .. are you at the beginning of the session or ?? cheers john
Not sure about that motherboard's chipset, X58, Socket 1366, with Pro Tools.
10 gb of RAM is a strange configuration. Have you done all the Avid optimizations? Do you have a CD or DVD in an optical drive? See the "Help Us Help" you link above the forum and try the troubleshooting suggestions there and also post a Sandra Report.
hi. definitely not using video.
when i tried setting the preroll in the transport window for a punch in. the 6 second delay before recording happened but no pre-roll. Of course not at the beginning of the track. it was for a punch in. I never had any issues like this with pro tools 8 LE. but I want to use pro tools on my new 64 bit OS |
never had an issue with 10Gig ram with pro tools 8 LE. The motherboard can take up to 12Gigs of RAM. Somehow I doubt that 2 more gigs would make a difference.
I am not sure what you mean by AVID optimizations. I don't have a cd or dvd in an optical drive |
how about your hard drive ??? i assume you are either SSD or 7200Rpm spinners ..
Hi ! I second john , the 10gb its a little strange at least for me . And as The Weed suggested please do the optimizations for you OS on windows . You can also tweak your Bios for better performance . For windows 7 install the lastest updates .
http://avid.force.com/pkb/articles/t...oting/en349411
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
not using pt8 on my 64bit OS but I have a 32 bit vista OS on the same desktop 2nd partition with pro tools 8 LE and it works flawlessly
I noticed. Regard my message as an error.
Mac Book Pro 2016 Retina, Quad core i7, 2,5 GHz, 16 Gb 1600 MHz RAM, 256 SSD drive, 500 Gb SSD USB3 OSX Sierra 10.12.5, PT 12.7.1, UVI Falcon 1.6 Metric Halo ULN8 3D Interface, NI Komplete Control S49 midikeyboard Macbook Pro M1, 2.5 GHz 8 core CPU, 32 Gb RAM, 1Tb storage, Monterey 12.6.6. PT Ultimate 2023.6, UVI Falcon 3.0 + some soundbanks, Waves Platinum bundle, some free Melda plugz, Metric Halo/Make Believe plugz. |
Do you by chance have "Count Off" enabled in your MIDI controls?
Save early and often! (or once a day whether you need to or not...) |
Delay before recording begins | RichrdC | Pro Tools M-Powered (Win) | 2 | 11-24-2010 12:24 PM |
Protools LE 7.4 time lag that occurs before recording begins | mlafargue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2008 03:27 AM |
protools quits before it begins | sinvida | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-29-2008 05:04 PM |
Pause Before Recording Begins | Zeek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-03-2002 12:54 AM |
really long delay before recording begins | Joseph Grimm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-09-2000 12:09 AM |
