  #101
Old 03-21-2013, 10:38 PM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Default Re: 44.1 kHz vs. 48 kHz - why not use the higher?
Originally Posted by Bob Olhsson View Post
There's no advantage in recording to 32 float files over 24 bit. There is an advantage to 32 float when calculating files with DSP such as Audiosuite or bouncing. The session setup window allows you to change it back and forth during a project.
Disagree.
32 bit float essentially gives you unlimited headroom.
Try this as demonstrated in a video by Russ over at pro-tools-expert.com (you have to have an account to view the video):
Set a clip's clip gain to clipping, so it's clipping the LEDs.
Bounce it out at 32 bit float. Bounce it again at 24 bit.
Suck those files into a session and AudioSuite Normalize them to 0db.
What result?
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
  #102
Old 03-22-2013, 02:04 AM
Top Jimmy's Avatar
Originally Posted by WombatStudio.Org View Post
Disagree.
Nope. 32-bit float does not give you unlimited headroom, it only gives you the ability to float the 24-bits used in the word above and below scale. There's still only 144 dB of SNR per sample.
And as Bob so knowledgeably stated, there is no advantage in recording 32-bit float files because there is no AD converter whatsoever that spits out 32-bit float words. All converters put out fixed point words with the best resolution being 24-bit.
James Cadwallader
  #103
Old 03-22-2013, 06:41 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
Default 44.1 kHz vs. 48 kHz - why not use the higher?
Which is why they are called 32 bit bloat in that context...
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
  #104
Old 03-22-2013, 02:29 PM
daeron80 daeron80 is offline
It's been a while since I watched that video. But, if I remember right, it actually demonstrates what Bob said. The video shows doing things with clip gain, right? Which is operating on audio that has already been recorded. In that sense, it's like Audio Suite. What the video doesn't show is recording an analog signal too hot and saving it with 32-float headroom. That's not a physical possibility.
David J. Finnamore
  #105
Old 03-22-2013, 03:06 PM
TOM@METRO's Avatar
Originally Posted by chrisdee View Post
I'v not been able to hear any difference between 44, 48, 88 or 96 KHz, but I'm only on an mbox 2 pro.
Maby better AD/DA converters would make it more audible ?
This has been backed up again and again in consumer blind tests. Let's think about the quality of converters in an ipod. However there are plug-ins that will sound somewhat better at higher sample rates. Whether or not this is enough to justify the additional resource needed is still hotly debated. I typically run 48/24. I feel if people can live with MP3s, they can live with the downside of the conversion to 44.1. Albee's point though still holds true. If you know that the project will never see film, 44.1 is fine.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #106
Old 03-22-2013, 04:00 PM
It's the badly implemented converters that show a marked difference in performance. Switching sample rate on the Lavry and Benchmark is telling in that regard.
Regarding the plugins and high sample rates, in my limited testing I've found it seemed to be the ones with oversampling that apparently benefited from higher sr. It may have to do with not having to up/downsample and/or having different/relaxed decimation filter values at higher rates.
Darryl Ramm
  #107
Old 03-22-2013, 06:38 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is online now
...If you know that the project will never see film, 44.1 is fine.
The problem is that we don't know and the highest quality playback our projects are likely to encounter in the future are film and video.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #108
Old 03-22-2013, 09:51 PM
And since most music mixes will generally do a trip outside the box to the analog world during mastering, the opportunity to simply capture it all back at 44 is always there.
Darryl Ramm
  #109
Old 03-22-2013, 10:43 PM
TOM@METRO's Avatar
Exactly the way I feel, this is why I record at 48/24.
~ tom thomas
Formerly hobotom
Windows 10
Intel Hexcore i7
  #110
Old 03-25-2013, 01:29 PM
gives's Avatar
gives gives is online now
After some further testing I have to correct my self. There is actually a pretty big difference between 44 and 96 KHz. Especially on the rtas effects (reverb, delay, etc) . They sound clearer and better in my opinion.
It also seem to be less of the pitchbend/chorus effect on DVerb at 96HKz.
On a dry track without any effects I can't hear the difference that much.
THis is true.. It's also hard to evaluate on a lower quality Interface with less quality A/D converters and so I am guessing that is why Avid has better ones as well. I DO hear a BIG difference here especially with all of the work that gets done here for films and other projects. Much cleaner and more transparent. It's all about what you are starting with, like cassette VS 2" tape at 30 ips. RIght.? -:)
Regards,
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
going higher than 10.6.3 viaspiaggia Post - Surround - Video 2 06-23-2011 04:41 AM
Can I get mp3.dll from 6.7 or higher? jonah day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-13-2006 01:54 PM
Anyone running higher than OS 10.3.4 with 001? duderonomi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-15-2005 07:59 PM
Anyone use JAM v.2.6 with OS 9.1 or higher?? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:38 AM
Higher Gain Tommyboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-22-2000 06:48 AM
