mix/edit window question
Just got my new PC build and Pro Tools up and running. so far so great!!
My question; is it possible to set the windows resolution so I won't need to scroll from top to bottom to see the entire channel strip? Also the plug in windows are huge and completely block my view of the respective window I am in. has anyone here found a trick or tip that enables me to get around these situations? I have played around with various resolutions but only the PC suggested resolution makes for a legible display. I am only running Pro Tools 10.0 which came on the installer disc and haven't upgraded to a recent update yet. Will an update correct this? I am using a samsung 32 inch LCD TV as my monitor with a hdmi connection. Thanks! Tony |
Re: mix/edit window question
It has some to do with resolution and some to do with how much info you choose to display(assuming you are running 1920x1080 as I do with a Panasonic 32"). You can select to NOT show stuff in the mix window, so, do you need to see all 10 inserts or send slot? By hiding 1 of each set, that may solve the issue. Also, if you only have 1 screen, you might consider a second LCD to one side so you can move plugins over to that screen(must of us run at least 2 screens, and some have 3 or 4)
Thanks Albee....
After digging around my screen resolution settings 1920x1080 works the best, I can see the entire channel strip in the smallest mix view, which i have always found nice to have. Set the TV/monitor to shrink the large picture resolution to the screen. Text can be a bit grainy but I get used to it. I do have a smaller flat screen I've considered using in addition. cheers. T- |
MIDI edit in Mix window question | SomeOtherGuy | Pro Tools 11 | 6 | 01-17-2014 11:39 AM |
Question on Edit window. | joesackic | Windows | 4 | 03-01-2011 10:29 PM |
8.01 and Edit Window/Color Question | acmost | Pro Tools TDM Systems (Mac) | 5 | 10-11-2009 11:25 AM |
Edit Window Automation Question | Jsswtpmp182 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-28-2006 02:08 AM |
edit window question | travista00 | Pro Tools TDM Systems (Mac) | 1 | 08-22-2005 04:34 PM |
