Old 12-02-2016, 11:29 PM
jeremiahmoore jeremiahmoore is offline
Default Re: Batch Fades with "F" key don't respect fade dialogue settings
In 12.6.1 release notes:
Fade length settings from the batch fades dialog are now used when pressing the single-key "f" command to create fades (PT-218064)
Old 12-08-2016, 06:12 PM
jseelye02 jseelye02 is offline
This is still not working like it used to though... it's changing the shape and length of already-in-place fades when you just hit "F" even if in the dialog you told it not to. It's closer I guess? Bummer.
Old 12-08-2016, 10:08 PM
Bummer.
I'm still on 12.5.2 for the time being; won't move to 6.1 until Jan.
The fade issue does slow me down. I have to use regular batch fades instead of F.
-j
Old 12-09-2016, 11:02 AM
john1192 john1192 is offline
Originally Posted by jeremiahmoore View Post
Bummer.
-j
hey jeremiah, if you have not trashed your prefs ... try that .. here is what i found ..
i was able to reproduce your Batch Fade replacing Existing Fades in 12.6.1 BUT when i moved Pt Version for testing (PT11,12.4,12.5,12.6, hence writing new prefs) it was gone .. now i cannot reproduce .. all works fine .. please try this .. john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 08-25-2017, 07:34 AM
stangroom stangroom is offline
Tried trashing prefs on 12.8 as we hadn't in awhile and still have to use the Command-F shortcut rather than simply pressing F. I know this thread is old, but what is the solution to this problem! It's changed my workflow to just use Command-F, but that's not a solution, nor is it faster.
Old 08-25-2017, 07:43 AM
Still waiting on one...
Old 08-25-2017, 08:28 AM
Yes... seems to be permanently broken. I generally have to use cmd-F instead.
A possible workaround would be to use a macro utility to map "F" to "Cmd-F" but this would break your ability to use the F key when doing other tasks such as simply typing (!) so ... I won't be doing it.
What's odd is: someone at Avid explicitly coded it to behave the way it does. And it's not that useful!
Does anyone prefer the way it behaves now, as opposed to before?
Old 08-25-2017, 08:46 AM
Hold the presses... this just in, from the 12.8.1 release notes.
I'm on 12.7.1 for the time being, may upgrade next week.
Fixed an issue that prevented fades from being shortened with the "f" key or fades dialog (PT-209093)
Using the f key to invoke the Batch Fades command no longer fails to recall the last used Batch Fades settings (PT-226439)
Old 08-31-2017, 08:13 PM
reducedfatoreo reducedfatoreo is offline
Did 12.8.1 finally do the trick? I haven't upgraded yet, but have been experiencing the same problem since we upgraded our post studios to 12. I'd love to go back to hitting 'f' instead of cmd-f. Seems, trite, I know, but when one has to batch fade dozens of times a day...
Old 09-03-2017, 10:13 AM
Yep, fixed! It's a miracle.
HTML code is On
12.5.1 batch fades from keyboard focus don't respect the dialog egray Pro Tools 12 4 09-30-2016 01:16 PM
Beat Detective: Region Conform "Strength" "Exclude Within" Settings ? sleepwalk Tips & Tricks 1 03-04-2016 11:37 AM
Batch fades: Why are fade IN and OUT the same value????????? Jason Rufuss Sewell Pro Tools TDM Systems (Mac) 0 11-18-2007 07:50 PM
Batch Fades....fade out only? Donnie Pro Tools TDM Systems (Mac) 0 02-27-2003 12:15 AM
Cross fades named "Fade hKivuUYViZuiDjg" Mick F. Cantarella Pro Tools TDM Systems (Mac) 18 07-01-2002 03:27 PM
