Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 09-13-2019, 08:00 AM
pablormago pablormago is offline
Default Fader 1 dont work in S3 with Dock
Hi to all, we have a small problem:
When S3 and Dock are conected, fader #1 acts insane!!
Is unselectable from S3 and if you move it it moves the last selected channel. It will work again normally only if you put the cursor on first track on Protools.
If we disconnect the dock, the #1 fader works normally again.
Any solution???
Thanks in advance
Old 09-13-2019, 09:36 AM
sjgam sjgam is offline
Default Re: Fader 1 dont work in S3 with Dock
This came up n the S3 forum. Its a bug and the workaround is to do the following:
In your 'My Surfaces' list, drag your Dock on top or in front of your S3. Functionality should return to normal.
Old 09-13-2019, 10:33 AM
Solved, thanks a lot...
Enviado desde mi SM-G950F mediante Tapatalk
First Fader of Artist Mix is stuck to whatever Dock fader is mrtomcat Artist Series 10 08-23-2019 02:51 AM
Dock fader sucks! Mike Landolt Avid S1, S3, Dock and Control 17 04-12-2018 09:18 AM
Dock Pre Fader Sends Color dalonso66 Avid S1, S3, Dock and Control 0 03-08-2018 12:57 PM
Fader off on Dock?? KPereira Avid S1, S3, Dock and Control 1 02-13-2017 01:22 PM
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control 0 10-01-2016 09:20 AM
