Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 08-29-2019, 02:05 AM
bassmagnetic bassmagnetic is offline
Default Anyone using DMG Equality with Dock and happy with knob mappings?
Equality has always been my default EQ, but it seems the knob mappings are completely counter intuitive on the Dock (and also S3), seems like maybe they are made for S6. Band 1 is on right side and 2 on left. HP and LP on different pages etc
Anyone know if its possible or how to change this?
Also is it possible to set the EQ button on the Dock to point to a specific EQ if there are multiple EQ's on the inserts? At the moment it will open the first EQ, it doesn't take into account what EQ is selected in Mixing preferences as default EQ and slot.
Thanks
Old 08-29-2019, 04:20 PM
BScout BScout is offline
Default Re: Anyone using DMG Equality with Dock and happy with knob mappings?
Mapping is up to the developer. Contact them.
There are also two different sets of maps: one is for the plugin type (so Eq in this case and shows up under EQ controls) and the other is Inserts (so shows under the general inserts section.)
You might want to look at both. I have contacted developers before when their mapping was off. Sometimes they didn’t notice since they were looking at only one of the maps.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-30-2019, 09:36 AM
reichman's Avatar
reichman reichman is offline
Thanks
I use Equality every day. I've given up on seeing intuitive mappings. I contacted DMG a while back. You should definitely reach out, too.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
New knob responce for the Dock Maro Records Avid S1, S3, Dock and Control 24 03-22-2018 05:31 PM
How can I export my plugin mappings and defaults? usastra Pro Tools TDM Systems (Mac) 2 12-26-2010 01:47 PM
FR - AIR instrument MIDI mappings remute Virtual Instruments 13 01-10-2009 10:44 AM
Bug in keyboard shortcut mappings? scratcher_x 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-18-2005 04:47 AM
fader mappings pleasedonthitme MIDI 0 05-02-2003 10:25 PM
