Eucon in PT12
Does anyone know if Eucon will work properly in Pro Tools 12 ?
It would be nice if all the basic work flow functionality we lost when Digidesign vanished & Avid took over & shoe horned Eucon into our lives, were reinstated so we could actually use the hardware WITH the software, get some product made, make some money & then… maybe then, we might make use of the "easy access to the Avid Store". Is it me ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: Eucon in PT12
Since there are separate drivers for EuCon, it should work fine after they fix the compatibility with Yosemite. I'm waiting for the fix to work with my MC.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Re: Eucon in PT12
"It should work fine"
Park, no offence, but you're missing the point. I think what you mean is it'll be seen by pro tools & won't crash. What I mean is: even in that scenario it doesn't do what we need it to do
Re: Eucon in PT12
I mean, since EuCon has NEVER worked right, not in one version since it's inception, I'm not sure why anyone would ever assume it will 'ever' work properly.
Re: Eucon in PT12
What are the issues you're seeing?
My controllers have been flaky (loses sync, fader response can be terrible at times) but I'm wondering what's common to others. |
Re: Eucon in PT12
Primarily the issue is that Pro Tools' mix & edit screens don't follow the banking performed on the hardware surface . . You do see the blue outline of the surface active faders in the Pro Tools windows, in my case 8 of them. . But when you bank to channels not visible on the screen it doesn't follow. Say I can see 16 faders on the screen for example, but have 32 channels in the session, if I bank up to faders 17 onwards the screen doesn't move along accordingly. . Pre Eucon this was never a problem, so for people who have moved to a Eucon surface from any earlier Digidesign surface this is an extremely annoying intuition.
Re: Eucon in PT12
I see you are running PT 11.3 and MacOS X 10.10.1 and also Artist control with Eucon 3.2.1. Does it work? |
Re: Eucon in PT12
My issues have been myriad. Examples:
ProTools refuses to see and talk to Mix and Control on startup, requires several power cycles of the units to get them to 'stick' At various times, hitting EQ simple no longer works, won't call up EQ settings. Graphic corruption on the OLED panels require restarts. Circular Panner cannot control Square Panner in PT cannot pan into the corner!!! The main problem people seem to have is reliable connectivity. Once mine are locked on, they stick 'most' of the time. But lots of people have had nightmares where they simply can't get their Artist series to talk to PT |
Re: Eucon in PT12
Not 100%. They need to update for Yosemite. They are aware of the issue
Re: Eucon in PT12
Yosemite needs new drivers to work. I am not listing all the features or all the misses in the software. I'd expect operationally to Be in line the last version that "worked".
Pt10+cptk >pt11hd >pt12 ?? | paul007 | Pro Tools 12 | 25 | 03-30-2016 03:15 AM |
PT12 has less Instrument Tracks? | adgjk | Pro Tools 12 | 48 | 01-25-2015 03:41 PM |
Pro Tools FAQ is now updated for PT12, etc. | nst7 | Pro Tools 11 | 120 | 01-25-2015 01:08 PM |
If we get the update to PT11 before 2015,how about PT12? | Rockman413 | Pro Tools 11 | 5 | 12-10-2014 11:09 AM |
