Old 04-04-2003, 02:20 PM
1150Post 1150Post is offline
Default PostConform 2.0.1 Problem
Any help on this one will be greatly appreciated.
I'm posting a doc with a very green editor who has digitized much of his audio too hot.
I asked for an EDL so I can redigitize the blown out reels.
Since we do so much work via OMF, in the year that this PT system has been around, I am the first person to try to run PostConform.
So I get my list, fire up PostConform, and PostConform won't import the file, as if it doesn't find it to be a valid edl.
No prob, take it into EDL Manager on a PC, create a verified clean CMX 3600 list. PostConform still doesn't think it's an edl, and still won't import it. Doesn't even list it as a file when the import box is open.
Clean it again with PreReader, another EDL cleaning solution. Same problem.l
So I have a video editor here create a short CMX list of the spot he's cutting from the Symphony. Same problem with this list. PostConform will not even list it as an importable file.
All files have the .edl extension, and I've tried upper case naming limited to 6 characters, and lowercase naming limited to 6 characters.
The edl I need to use but can't was made on Final Cut Pro, and the test file edl I had made to check out my box was made on a Symphony.
Ant thoughts? Luckily, the client is giving me a some time to cut and mix this show because he knows it's a bit of a mess, so I've got time to work this out.
Thanks for the feedback and input!
Brad McIlvaine
Audio Mixer/Designer
Henninger Digital Audio/1150 Post
Washington, DC 20036
Brad McIlvaine
Sr. Mixer/Designer
Henninger Media Services
Old 04-04-2003, 07:42 PM
ChrisMac ChrisMac is offline
Default Re: PostConform 2.0.1 Problem
try changing the suffux to .txt I've had problems with PC not seeing .edl files and changing it to a .txt file has solved the problem
Chris McIntosh
President/Sound Supervisor
Postal Audio Inc.
Imdb
Facebook
Old 04-07-2003, 08:25 AM
This was the fix! Many thanks. Now, if I can just get the reels I need, I might be in business again!
Thanks again.
Brad McIlvaine
Sr. Mixer/Designer
Henninger 1150 Post
Brad McIlvaine
Sr. Mixer/Designer
HTML code is On
Postconform to OS 10.X JimC Post - Surround - Video 17 08-06-2004 10:25 PM
VSD and SSD with Postconform? Clubsoda Post - Surround - Video 1 09-26-2001 08:22 AM
PostConform here? Danny Caccavo Post - Surround - Video 1 06-13-2001 09:15 PM
New PostConform diver Pro Tools TDM Systems (Mac) 1 10-28-1999 03:17 PM
*** POSTCONFORM *** POSTCONFORM *** POSTCONFORM *** Musiclab General Discussion 2 07-21-1998 09:44 AM
