Old 11-26-2020, 03:17 AM
kevo.colmanbertoni kevo.colmanbertoni is offline
Default Pro Tools 12 - Slow response
Hello how are you? I'm new to the forum so I send you a big hug.
I recently went from Mac to PC (Windows 10 Pro). I always worked with Pro tools 10.3.10 and now I move to 12.5.
I am having problems with peaks of 100% use of my cpu and also with slow responses when using clip gain or moving groups of tracks.
I work in sound editing for cinema so my sessions usually have at least 50 audio tracks and 10 aux added to a running video.
I am wondering if the problem may be my new i5 10400 2.9 Ghz processor.
My computer:
I5 10400
Avid Mbox Pro 3 for Pro Tools and Zoom F4 for Windows
Saphire Radeon Rx 570
32 Gb Corsair 3000 Mhz
Kingston SSD 480 for Os and two kingston SSD 120 for audio and video.
SiSoftware Sandra
Identifier
Host name: DESKTOP-4GA8COD
Workgroup: WORKGROUP
System
Model: MSI MS-7C82 Default string
Serial number: Default *******
System Chassis: MSI Desktop
Main board: MSI MAG B460M MORTAR WIFI (MS-7C82)
Serial number: K6162 *****
System BIOS - AMI (OEM) 1.10 05/18/2020
Intel vPro: 14.5.12.1111
Total memory: 32GB DIMM DDR4
Processors
Processor: Intel (R) Core (TM) i5-10400 CPU @ 2.90GHz (6C 2.9GHz / 4.3GHz, 2.6GHz / 4.3GHz IMC, 6x 256kB L2, 12MB L3)
Socket / Slot: FC LGA1200
Chip set
Memory Controller: MSI Core10S (Cometlake-S 6C) Host Bridge / DRAM Registers 100MHz, 2x 16GB DIMM DDR4 2.67GHz 128-bit
Memory module (s)
Memory module: AMI CMK16GX4M1B3000C15 16GB DIMM DDR4 PC4-21300U DDR4-2666
Video system
Monitor: Samsung S24F350
(1920x1080, 23.5 ")
Monitor: Hewlett Packard HP L1740
(1600x1200, 16.8 ")
Monitor: PHILIPS FTV
(1600x1200, 31.5 ")
Video adapter: Radeon RX 570 Series (2304S 32C SM6.5 1.14GHz / 2GHz, 4GB DDR5 7GHz / 9GHz 192-bit, PCIe 3.0 x16)
Video adapter: Radeon RX 570 Series (2304S 32C SM6.5 1.13GHz / 2GHz, 4GB DDR5 7GHz / 9GHz 192-bit, PCIe 3.0 x16)
Graphics processor
OpenCL: Radeon RX 570 Series (2048S 32C SM2.0 927MHz / 1.27GHz, 4GB DDR5 7GHz / 9GHz 256-bit)
D3D 11: Radeon RX 570 Series (2304S 32C SM12.0 640MHz / 1.27GHz, 4GB DDR5 7GHz / 9GHz 192-bit)
OpenGL: Radeon RX 570 Series (2304S 32C SM4.60 966MHz / 1.27GHz, 4GB DDR5 7GHz / 9GHz 192-bit)
Physical storage devices
Disk: KINGSTON SA400S37120G (120GB, SATA600, SSD)
Disk: KINGSTON SA400S37480G (480.1GB, SATA600, SSD)
Disk: WDC WD10EZEX-75M2NA0 (1TB, SATA600, 3.5 ", 7200rpm)
Disk: KINGSTON SV300S37A120G (120GB, SATA600, SSD)
Disk: WDC WD1003FZEX-00MK2A0 (1TB, SATA600, 3.5 ", 7200rpm)
Drive: Seagate ST4000LM024-2AN17V (4TB, USB3 / SATA600, 2.5 ", 5526rpm, SED)
Logical storage devices
Hard Drive (E :): N / A
Hard Drive (C :): 447GB (NTFS, 4kB) @ KINGSTON SA400S37480G (480.1GB, SATA600, SSD)
BLUE (F :): 932GB (NTFS, 4kB) @ WDC WD10EZEX-75M2NA0 (1TB, SATA600, 3.5 ", 7200rpm)
VIDEO (G :): 111GB ​​(NTFS, 4kB) @ KINGSTON SV300S37A120G (120GB, SATA600, SSD)
Hard Drive: 505MB (NTFS, 4kB) @ KINGSTON SV300S37A120G (120GB, SATA600, SSD)
BLACK (D :): 932GB (NTFS, 4kB) @ WDC WD1003FZEX-00MK2A0 (1TB, SATA600, 3.5 ", 7200rpm)
LIBRARIES (I :): 4TB (NTFS, 4kB) @ Seagate ST4000LM024-2AN17V (4TB, USB3 / SATA600, 2.5 ", 5526rpm, SED)
Hard Drive: 96MB (FAT32, 1kB) @ KINGSTON SA400S37480G (480.1GB, SATA600, SSD)
Hard Drive: 96MB (FAT32, 1kB) @ KINGSTON SV300S37A120G (120GB, SATA600, SSD)
EFI: 197MB (FAT32, 512bytes) @ Seagate ST4000LM024-2AN17V (4TB, USB3 / SATA600, 2.5 ", 5526rpm, SED)
Peripherals
LPC 1 Hub Controller: MSI Intel (R) LPC Controller (B460) - A3C8
Audio device: ASRock Ellesmere [Radeon RX 580]
Disk Controller: MSI 400 Series Chipset Family SATA AHCI Controller
Disk Controller: MSI Intel (R) PMC - A3A1
USB Controller 1: MSI Intel (R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
Biometrics
Voice: Analog NUI Voice Virtual Sensor (Voice)
Peripherals
Media player: Seagate Expansion (3.64TB)
Network services
Network adapter: Bluetooth Device (Personal Area Network) (Ethernet)
Wireless WiFi Adapter: Intel (R) Wi-Fi 6 AX200 160MHz (802.11n (HT), AES-CCMP, 115.6Mbps / 130Mbps)
Operating systems)
Windows system: Microsoft Windows 10 Professional 10.0.19042
Platform compliance: x64
Performance improvement suggestions
Warning 2513: TPM not detected. Some security capabilities are not available.
Tip 2: Double-click the tip or press Enter while a tip is selected to get more information about the tip.
THANKS!
Last edited by kevo.colmanbertoni; 11-26-2020 at 02:55 PM. Reason: More information
Old 11-26-2020, 09:21 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools 12 - Slow response
What optimizations have you done? Have a look here.
Also search the Forum for "Processor Affinity".
An i5 could be considered "light", but if it's the "F" iteration, it has 6 cores.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-26-2020, 12:13 PM
A few more things to consider:
1-post a Sandra report(see the Help Us Help You link above)
2-Windows 10?
3-if you have a CD/DVD drive, make sure there is no disk in the drive.
4-with intel CPU's, is it possible that an nVidia graphics card would be a better choice(I'm not sure)?
5-a pair of 120GB drives for audio and video seems way small(to me). How much free space on each of those drives? Over 80% full might cause some slowdown.
6-It sounds like you need a pretty potent machine, so I tend to agree with The Weed on the i5 maybe being over-taxed(assume you already pushed the playback buffer as high as it goes?)
Old 11-26-2020, 02:57 PM
Hello! Thank you very much for the reply.
I already made all the recommendations you indicated and not much has changed.
Other information that is important is that you deactivate the Turbo Boost and the hyperthreaded. And I usually work with three image monitors at the same time, although the video card is not the problem.
Old 11-26-2020, 03:01 PM
2-Windows 10?
1 - Thank you very much I just posted a report from Sandra.
2 - Windows 10 Pro.
3 - I don't have Cd drive.
4 - Radeon Graphics runs good!
5 - I only use it for the session I am using, it is usually free more than half of its space. I have other discs for data.
6 - Do you think that the change from an i5 10400 to an i7 10700k would solve the fluidity of work within heavy sessions?
Slow response after scrub GS-DK Pro Tools TDM Systems (Mac) 1 02-29-2012 02:28 AM
slow response tonwurm Pro Tools TDM Systems (Mac) 12 12-18-2008 05:56 PM
Slow response. Help please! rodrigo21 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-04-2005 11:04 AM
slow menu response euphjazz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-22-2004 09:28 PM
