Plug-in advice needed
Helping to put together an HD system with some friends. We want to make sure we have a well rounded array of quality plug-ins.
Waves? They're a little expensive, but are they really worth the money when compared to other packages out there? It would be the Gold Bundle most likely. Anyway, looking for some suggestions. Thanks! |
Re: Plug-in advice needed
What are you intending to do with your HD system? Sound tracks? Pop music? Classical?
PT9.0.0, 3.0GHz Mac Pro, OS 10.6.3, 13GB RAM, HD6/Accel, Magma PE6R4, PRE |
I have the Waves Gold bundle, and it was a great investment IMHO. I use these plugs on every session and mix.
I would also recommend Sound Toys Echoboy.
Have a great day..... Bill ---------------------- Mac Mini (2019) 3.2 Ghz - 6 Core i7 Mojave with 64 GB RAM PT Ultimate (2019.10) Motu 16a C/24 Control Surface |
Lots of rock, metal, and a good mix of other genres as well.
Waves is good for both sound and efficient use of the HD DSPs. I started with Gold and eventually upgraded to Diamond. In addition to the capabilities of Gold, Diamond has TransX, H-Comp, and GTR3 all of which have become indespensible.
Buy Waves from [email protected] for the best prices and watch out for discounts for NARAS membership, $100/yr and worth it for the discounts alone.
Ok, so all of these may not be practical. But I use these more than any others.
- Waves Mercury TDM - essential! And get the GTR interface - Waves SSL 4000 TDM - SoundToys TDM Effects - UAD plugs with UAD-2 Quad(s) - Neve, etc - Abbey Road/EMI - all plugs - AutoTune Evo - Arturia V Collection - AltiVerb - Celemony Melodyne Plugin - Digidesign TDM: Eleven, ReVibe, Smack!, Reel Tape Suite - Eventide Anthology II TDM - BFD2 with Andy Johns - GForce synths including MTron Pro - MDW EQ TDM - AVOID any NI plugs - Sonnox - all TDM plugs - Spectrasonics - Stylus RMX Expanded, Omnisphere - Synthogy Ivory - TC Electronic - all TDM plugs - Vienna Symphonic Library - Special Edition, Vienna Ensemble Pro raw |
Also check out bundles from URS and McDSP.
www.clifnorrell.com |
UAd 2 and everything they got,its better than all of that over priced stuff....
For heavy stuff, you should definetely demo Waves SSL. Also take a look at Drawmer Dynamics and Massey L2007. And you can never go wrong with Sonnox EQ and Dynamics.
But what is more important is your preamps and mics. I presume you already have a nice selection of mics, but what preamps are you using? You should have something that has massive dynamic range for the drum kit, but also something that has built-in analog compressor for the rest of the band. Slight compression on the way in makes it easier to mix. Most plugin companies offer time-limited demos; good luck.
There's an M 80 in the rack, a Meek, and an Avalon.
I was not responsible for choosing what is already there. |
Advice needed on plug in compatability with PT11 and upgrading | rockguitarist1255 | Pro Tools 10 | 7 | 04-07-2013 09:03 PM |
PLUG-INS - ADVICE NEEDED | JackSummer | Tips & Tricks | 1 | 07-07-2008 05:02 PM |
Advice Needed ! | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-19-2007 12:22 PM |
Mastering Plug-in advice needed | Vastapol | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 04-30-2002 02:07 PM |
Plug-in application/mixer advice needed. | jpoprock | Tips & Tricks | 2 | 04-25-2002 03:47 PM |
