Old 03-20-2017, 10:19 AM
golsf golsf is offline
Default Guidance on Incorporating Eleven Rack
I am looking for guidance and advice on how to best incorporate the Eleven Rack into my recording rig. I recently acquired the Eleven Rack to produce better recordings of guitar, particularly with high gain sounds that are difficult to capture in my home studio without annoying neighbors.
I currently have a Digi 003 which has been modded by Black Lion Audio to incorporate better A/D processors, midi clock, pre-amps, etc. I also have an Avalon 737 preamp.
With the setup described above, how would others recommend I incorporate the 11? Should I use the Avalon's line input into the Eleven, and then output via SPIDIF to the 003 to take advantage of the better mic-pre on the way in and the better A/D processors on the way into my PC? Any advantages to the True-Z feature on the 11's input? Is this lost when going in through a different pre-amp?
Thank you in advance
Old 03-21-2017, 06:27 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Guidance on Incorporating Eleven Rack
Personally I'd just connect the Eleven Rack using USB and set it as the audio interface when recording guitars. But you could use the SPDIF out of the Eleven Rack to the SPDIF in of the 003 instead.
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 03-21-2017, 03:42 PM
Hi Joel,
Thank you for your comments. I have read that two of the ER's shortcomings are the quality of both the pre-amp and A/D conversion circuits. I was looking to bypass both in favor of better componentry elsewhere in the signal chain.
I believe this would be achieved by using a better pre-amp and outputting digital signal that my 003 rack could then convert.
Am I considering this the right way? Also, is the True-Z capability lost when using a pre-amp in front of the ER?
Old 03-22-2017, 07:25 AM
JoelG's Avatar
But the AD conversion would still be happening in the Eleven Rack either way. And you'd still be using the Eleven Rack's preamp too, just inserting another in front of it. If you specifically want to colour the sound with your Avalon, then that's a different story.
If you want to get the most out of your Avalon and the converters in the 003, then you could not use the Eleven Rack at all and get your distortion from a plugin like Eleven MKII.
Joel
Jame Space:
Home:
Rig:
Old 03-22-2017, 08:57 AM
My dreams of analog purity dashed ...
Of course you're right ... The signal would be converted into digital on the way into the ER even if I use the 003's converters on the way out.
I'm really enjoying the ER having got it relatively stable and learning how it works with PT10 and the 003.
I am having issues using the S/PIDIF outputs ... I'm getting a lot of digital signal interference when tracking in PT10 which I don't hear when plugging directly into the headphone jack of the ER (which sounds beautiful).
I've learned how to set the clock to external via S/PIDIF and confirm via the Control Panel in Windows 7.
Not sure if my S/PIDIF cable is up to par. They were previously used for a digital application, but I'm not sure if they're 75ohms. I've ordered a pair of Mogami designed for audio application.
Any other potential culprits I should check?
Old 03-22-2017, 10:04 AM
JoelG's Avatar
Sorry to be the bearer of bad news
I'm quite happy with my 11R, but mostly use it "live" more then recording.
I'm not sure what would be causing any signal issues with your SPDIF connection, and while I have no doubt that a good cable is the way to go, we're talking 1's and 0's here, if one of them doesn't arrive properly it would be quite noticeable with pops or dropouts, not like analogue where you'll get hiss or unwanted distortion.
Joel
Jame Space:
Home:
Rig:
Old 03-22-2017, 09:04 PM
bronsoncox bronsoncox is offline
Run your Avalon to the modded A/D on your 003. Use this IO for your dry guitar tracks.
SPDIF back and forth to your Eleven Rack and set its Rig Input to the appropriate Digital Input (same for output). Grab the IO from the 003 SPDIF input for your Eleven Rig tracks. True Z should still be affecting your signal at this point.
Here is a link to a clocking article for this specific scenario since the BLA modded 003 should have a superior one that you would want to set as master.
http://avid.force.com/pkb/articles/e...ow_to/en345879
I haven't tried something like this but the latency between units should be minimal since no additional ADA conversion is taking place. Still a good idea to check for phase between your dry tracks and the Eleven Rig tracks.
Old 03-22-2017, 09:28 PM
Many thanks for the guidance and article post. I'll give that method a try when the SPDIF cables arrive tomorrow.
Check out the Eleven Rack Presets Matched for Eleven plugins by Pro Tools Expert! Justin1524 Eleven Rack 0 11-27-2015 02:53 PM
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
incorporating analong mixer with 002 rack ??? alecmcmahon Tips & Tricks 4 10-24-2004 11:18 AM
