Feeding the USD with LTC Pro Tools will randomly fall out of sync and stop playback. Works fine in os 9 pt 5.1, any ideas? Also noticing extended times to lock to incoming code.
Using G4 850, Plenty o' Ram, OSx.2.8 |
What is your Minimum Sync Delay set to in Peripherals>Syncronization? Try increasing it.
Also, if you're recording, make sure to limit Open Ended Record in Setups>Preferences>Operation. Specify a value of minutes rather than "use all available." -Jordan |
Update,
Actually sync is fine when using the deck as the transport master. If machine control is used in PT is when it falls apart. So, I guess this is a machine control issue. Update again: Using the Gport for control, looks as though it's not supported, anyone using usb-> serial, will that work?? |
Yep, Keyspan USA-28x USB to serial is your best bet.
-Jordan |
Pro Tools Losing Internal Sync | edit machine | Pro Tools TDM Systems (Mac) | 2 | 12-14-2010 10:47 AM |
losing sync while auditioning in the workspace | minister | Pro Tools TDM Systems (Mac) | 7 | 09-24-2006 07:27 PM |
M-powered losing TC sync | Eric Seaberg | Pro Tools M-Powered (Mac) | 1 | 04-19-2006 10:49 PM |
PT losing sync... | Raven | Pro Tools TDM Systems (Mac) | 1 | 07-24-2002 05:07 AM |
USD losing sync among other things :P | babyseal | Pro Tools TDM Systems (Mac) | 3 | 02-25-2001 01:45 AM |
