System : PT HD3 + 192 I/O with DA card + Sync I/O.
Connection : SMPTE from 24 track (2" Studer tape) is fed to SMPTE In of Sync I/O. Word Clock out of Sync I/O is given to WC in of the 192 I/O. Session Setup : Session is at 48kHz. Clock source - Internal. Positional Ref - LTC Hardware setup - 192 is set to Clock source - Word Clock 48kHz When running a session in sync with the tape, by putting PT 'online', there is a drift. This does not happen all the time.. e.g PT is recording two tracks and everything is in sync and is all fine. If we go for a re-take, the PT is running slightly off-sync with the tape!! Sometimes, you play back the same place and it is in sync again!!!! What can be wrong? Any suggestions? This is a prestigious client. Thanks |
You're getting drift cause your 2" is the master...it should be code-only master (i.e. used as positional reference...SMPTE...for Pro Tools).
You need to invest in a synchronizer (such as a Time-Line MicroLynx) and a blackburst generator. Clock Reference: Blackburst to both a MicroLynx and a Sync I/O. MicroLynx resolves to blackburst and in turn resolves the servo of the 2" machine. Sync I/O also resolves PT to blackburst. Positional Reference: Timecode out of track 24 of the 2" into the Sync I/O. Put PT online (command+j), press play on the 2" and PT receives the SMPTE trigger point and follows along. |
Pro Tools Losing Internal Sync | edit machine | Pro Tools TDM Systems (Mac) | 2 | 12-14-2010 10:47 AM |
losing sync while auditioning in the workspace | minister | Pro Tools TDM Systems (Mac) | 7 | 09-24-2006 07:27 PM |
M-powered losing TC sync | Eric Seaberg | Pro Tools M-Powered (Mac) | 1 | 04-19-2006 10:49 PM |
Losing Sync with USD, 6.1, OSX | Syncman | Pro Tools TDM Systems (Mac) | 3 | 11-05-2003 03:49 PM |
USD losing sync among other things :P | babyseal | Pro Tools TDM Systems (Mac) | 3 | 02-25-2001 01:45 AM |
